Topped Orange coolant off with Green.
Old May 22, 2015 | 06:19 AM
adough's Avatar
About a month ago(maybe a little more) I topped of my radiator and overflow with green coolant. It had orange coolant in it and I didn't even notice. Yesterday on my way home I noticed my temp gauge got just above halfway, put on the heat and it went back down. Same thing today. Have I royally messed up my system by blending? I appreciate any input. Not wanting to spend $105 on a system flush.
Old May 22, 2015 | 10:26 AM
RustBucket's Avatar
Get some proper coolant. My favorite is peak global lifetime from Napa mixed with distiller water.
No need to "flush". Just drain radiator and block drain. Fill with distilled water, run for a minute, drain back out. Fill up with the right stuff.
Old May 22, 2015 | 10:54 AM
adough's Avatar
So, no need to worry about the coolant already in the engine just the radiator? If that is the case, I feel very relieved. Thought I had turned my coolant to gel.
Old May 22, 2015 | 08:34 PM
RustBucket's Avatar
You need to drain all the coolant, radiator and engine block. No telling what mixing coolant chemistries will do.
Old May 23, 2015 | 01:01 PM
Terrys87's Avatar
You need to drain all the coolant out. It is not recommended to mix the red and green coolant. I have heard pros and cons on the red coolant so not real sure about it. The green has worked for years for me so I tend to stay with it. I am sure my 01 runner has red in it and no problems with it.
Old May 23, 2015 | 05:30 PM
mct75's Avatar
Wait, was the coolant really orange? If that truck had dexcool in it you're gonna have a bad time.
Old May 25, 2015 | 08:23 AM
adough's Avatar
It was "universal orange" and I added "universal green." I didn't add much probably in the ounces. Thinking I'll flush the radiator, run it a bit and flush it again.
Old May 25, 2015 | 08:32 AM
thook's Avatar
So, who put the orange coolant in? Just because it's orange doesn't mean it isn't chemically compatible. Seems I recall having used an orange coolant some time ago without issue. I use Prestone low-tox anymore, though.
Some internet reading may alleviate your concerns...
http://www.aa1car.com/library/2004/us120426.htm
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
JaredL
Mar 28, 2016 09:08 PM
TJWilly
Jul 31, 2015 02:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
