Tdc
Old May 23, 2015 | 12:36 AM
altydog's Avatar
Tdc
I have a 1991 toyota pickup with 22RE engine, EFI, automatic tranny. Is TDC 0 or 5 degrees and do you know the page in the FSM that mentions this? Thanks
Old May 23, 2015 | 07:08 AM
rustypigeon's Avatar
TDC by definition is 0 degrees.
Ignition timing is 5 degrees BTDC at idle with terminals TE1 and E1 connected. The distributor is installed with the engine a 5 degrees BTDC as well.
The ignition section of the FSM mentions this.
http://personal.utulsa.edu/~nathan-b.../5distribu.pdf
Old May 23, 2015 | 12:40 PM
Terrys87's Avatar
A Timing Video I like Better. Set Crankshaft pulley to 5 degrees.
Timing Video
http://www.youtube.com/watch?v=9qEQM...ature=youtu.be
Easy way to install distributor on Youtube.
Marsheen
Feb 17, 2016 12:29 PM
voiddweller
Sep 28, 2015 11:21 PM
PBRaddict#1
Sep 22, 2015 07:50 AM
Jason Webber
Sep 2, 2015 03:30 AM
cgilley
Jul 25, 2015 10:55 PM
