22RE Cold Air Intake pros v cons Help
Old Jun 5, 2015 | 05:22 AM
Rodlaw11's Avatar
88 4Runner 22re. Thinking about adding a cold air intake to my runner. Is this a good idea? What are the pros and cons? Best product? Thanks!
Old Jun 5, 2015 | 07:06 AM
Robert m's Avatar
You wont gain anything but noise with a aftermarket CAI. Save your money for something else
Old Jun 5, 2015 | 08:56 AM
Janos01's Avatar
In my opinion, the best mod for 85-95 Trucks and 4runners is a good set of headers. You really wont see an difference with mods like that.
Old Jun 5, 2015 | 10:23 AM
wyoming9's Avatar
Red face
Unless you build your own to be a true Cold Air Intake they are most often worse then stock depending what climate you live in.
Now if you like to play in the water a real snorkel that pulls air from up around the roof is of help
Old Jun 5, 2015 | 10:35 AM
kcaudill's Avatar
I have a K&N FIPK, Save your money for other mods, Like said, makes allot of noise with no or little gain
Old Jun 5, 2015 | 10:59 AM
osv's Avatar
osv
your 22re 4runner should already have a cold air intake from the factory, it pulls air in from the high pressure area behind the front grill, outside of the engine compartment.
it's a plastic tube, that has the end bent over slightly, to keep direct airflow from being forced into the tube, and it's connected to the air box beneath the filter... i can't find a picture of it.
88sasturbotoy
Jan 30, 2026 01:57 PM
Doug4320
Mar 24, 2018 10:11 PM
msane99
Jul 27, 2015 06:14 PM
ryerye13
Jul 14, 2015 08:27 AM
tpd143
Jul 7, 2015 09:06 AM
