Will start but wont idle
Old May 14, 2015 | 06:27 AM
JPolk's Avatar
i just put a new Cylinder head, timing chain, oil pump, and water pump on my 22RE but when we went to crank it it just wouldnt turn over for awhile. after many attemps to start it it finally started but it wont idle on its own. Anyone now what might be the cause of this?
Old May 14, 2015 | 06:39 AM
scope103's Avatar
Ignition timing? If you don't have a timing light, you can't get it close enough to run.
Old May 14, 2015 | 06:45 AM
JPolk's Avatar
il have to check that one, everything else is timed as best as we could
Old May 14, 2015 | 10:12 AM
thook's Avatar
Rotor alignment? Did you align it at 11 o'clock? After that, and setting ignition timing, make sure you didn't leave any vacuum hoses detached and everything vacuum related is sealed well. When I last did my timing chain/eng. rebuild, I didn't get the cold start injector switch sealed well to the plenum and it wouldn't idle well at all......of course.
Old May 14, 2015 | 10:58 AM
RBX's Avatar
RBX
^^^ what he said, especially check vacuum lines.
Old May 14, 2015 | 05:03 PM
JPolk's Avatar
I do have a metal pipe that runs coolent behind the engine that leaks fairly good. It goes into the underside of the intake but the problem is the bolts broke of in the holes and it wont tighten up so it drips
Old May 14, 2015 | 06:53 PM
thook's Avatar
Well, certainly that should be fixed, but what I was referring to is vacuum hoses and things that attached to the plenum. A coolant leak such as that wouldn't prevent the engine from idling.
Charecter1
Nov 6, 2023 10:08 AM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Jnkml
Jul 6, 2015 01:20 PM
karbin
Jul 5, 2015 11:37 PM
