91 4runner timing issue
Old May 29, 2015 | 06:06 PM
Griffey87's Avatar
I have a 91 4runner and when I put it in time (as the manual and schematic on the hood says to do) it will run fine at idle, but then if I go to drive it the cel comes on and it loses all it's power. What could possibly cause this???
Old May 29, 2015 | 06:24 PM
Shagool22's Avatar
Did you read CEL code yet?
Old May 29, 2015 | 06:33 PM
Griffey87's Avatar
I'm getting code 24 which is inlet air temp sensor, and code 51 which is ignition switch which I replaced with a brand new one today but I still have the same problem
Old May 29, 2015 | 09:54 PM
grumpin's Avatar
I don't think code 51 is the ignition switch. 1988 FSM says, A/C switch circuit, A/C switch, A/C amplifier, TPS Circuit, TPS, (A/T) neutral start switch circuit, (A/T) neutral start switch. 1993 says, TPS IDL circuit, PNP switch circuit, accelerator pedal cable, ECM. I don't have access to a 1991 manual, but hope these will help. And I don't know what PNP is.
Old May 30, 2015 | 04:29 AM
Griffey87's Avatar
I'm kinda new to the diy diagnosis and I believe I read the codes wrong, I think they was, 24,25,21 which all can be symptoms of a bad o2 sensor. Does this sound more like what could be causing my problem?
Old May 30, 2015 | 04:44 AM
wyoming9's Avatar
Red face
Just what engine?
You are jumpingT E1 to T1 on the check connector??
Before adjusting the timing ??
Old May 30, 2015 | 04:47 AM
Griffey87's Avatar
It's the 3.0 v6, and correct I am jumping the 2 in the diagnosis box before performing timing.
Old May 30, 2015 | 08:43 AM
Shagool22's Avatar
PNP- park/nuetral position switch.
Old May 30, 2015 | 12:01 PM
grumpin's Avatar
Thanks!
voiddweller
19
May 2, 2016 09:10 PM
WI Girl
Jun 25, 2015 03:45 AM
crazypaint
Jun 23, 2015 03:27 AM
saphirekosmos
Jun 22, 2015 10:26 AM
bobbybouche
Jun 18, 2015 10:22 AM
