5 spd tranny
Old May 22, 2015 | 07:01 PM
greaseball's Avatar
5 spd tranny
i have a 5 spd tranny out of a 1980 pickup with a 20r motor. the only problem with it is 5th and reverse gears are a little iffy .they were towing a nissan pathfinder across washington state from seattle to spokane and as they were going uphill in vantage they downshifted and missed a gear. it looks like just two gears are affected. are these easy to fix and will it bolt up behind a 22r in a 88 pickup?
Old May 23, 2015 | 12:32 AM
dropzone's Avatar
Fossilized
it will bolt up behind any 22R but the problem with an L Series transmission out of a 1st Gen (79-83) truck is that it is 4" shorter than the W Series transmission in an 88. You would need to move the crossmember forward, lengthen the rear driveshaft and shorten the front driveshaft to make it work.
You would be better off finding a G or W series 5 speed to use as a replacement since they would be direct replacement
Old May 23, 2015 | 12:38 AM
wyoming9's Avatar
Red face
Besides what Dropzone said !!!
One never knows just what one may find once things like that come apart.Some parts might be very hard to find as well
I would say get a Marlin Crawler rebuilt and be done
Old May 24, 2015 | 11:49 AM
greaseball's Avatar
i was thinking more along the line of pull and save to save a little money.
Old May 24, 2015 | 12:13 PM
wyoming9's Avatar
Red face
Well one needs to work within the budget.
I got a used W-56 I got a month out of it till I had to drive holding it in gear.
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
Dale Johnston
11
Oct 31, 2015 10:22 PM
