Distributor issues
Old May 31, 2015 | 08:25 PM
Alex Bessinger's Avatar
Distributor issues
Hi there,
I just recently bought an 89' pickup and swapped the old 3.0 with a newer one. I got the engine to start, but it will only start/run if the distributor is rotated all the way to the right (if you are looking straight at the distributor). I'm quite sure this isn't normal so I'm wondering what the cause is?
Thanks
Alex
Old May 31, 2015 | 08:26 PM
Also the engine runs pretty rough, not sure if related or due to vacuum lines being old and split...
Old May 31, 2015 | 09:23 PM
scope103's Avatar
And your timing light says ... ? They're only $20; trying to set timing without a timing light is just another name for blowing a hole in a piston.
When the distributor is removed, it has to be put back in "the right way." The helical distributor gear has 13 teeth, so if you are off one tooth the timing will be off about 28°.
http://personal.utulsa.edu/~nathan-b...13distribu.pdf
Sleaker
Aug 26, 2020 06:03 AM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
raptor510
Aug 19, 2015 02:15 PM
smiley52
Jul 11, 2015 05:16 AM
