Issues when cold
Old May 15, 2015 | 02:28 PM
RacerX2015's Avatar
Issues when cold
I have a 1991 Toyota DLX pickup w 3L V-6. In the morning when I start the truck it will hardly idle. Idles REALLY slowly and seems it might also be missing. But if I give it a little gas it seems fine. Doesn't have this issue after it gets warm. Not a big FI person. Know a little, but not a lot. Seems to be a choke issue, but I don't think that it has a choke. Any ideas what to look for?
Thanks
Old May 16, 2015 | 04:22 AM
thook's Avatar
No, there's not a "choke" as with carb'd engines. EFI doesn't need one. (Or, rather, it uses different technology for the same purpose.) Your EFI does have a cold idle air valve, though, which could be what's giving you problems. It allows extra air passed the throttle plate when the coolant/engine is cold and shuts off once the engine starts warming. So, run a search on that. They are fairly simple to test. Also, search through the troubleshooting guide under your given symptom...
http://personal.utulsa.edu/~nathan-b...63troubles.pdf
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
shisha1999
Sep 21, 2015 08:22 PM
calderp
Jul 27, 2015 09:58 AM
ty1er
Jul 19, 2015 06:42 PM
