Injector Swap Problem
Old May 19, 2015 | 04:28 PM
Pete1122's Avatar
I just installed a set of new Flamethrower injectors on my 1989 3.0 Pickup. I put everything back together and now the engine shakes at low RPM and sounds like it is missing. I pulled each spark plug wire and found that number 3 and 5 makes no difference when I pull the plug.
I do get spark out of each wire, does this mean I somehow installed injector 3 and 5 wrong or they are defective? What else could it be?
The thought of pulling the Plenum again makes me want to cry a little.
Old May 19, 2015 | 10:06 PM
Robert m's Avatar
As much as it sucks, I would pull them and switch them around with different cyls and see if the issue moves with the injectors.
Old May 20, 2015 | 08:34 AM
Pete1122's Avatar
Can I reuse the Plenum gasket? It's been on for only a few days. Also will I need to use all new crush washers for the fuel lines? New gaskets for the EGR system as well?
Old May 20, 2015 | 11:45 PM
Robert m's Avatar
Cant guaranty it wont leak but I've done it before on my 22re.
Old May 25, 2015 | 07:47 AM
maxisdrunk's Avatar
I had the same problem with 1 new flamethrower injector on my 22re. Tested it and it showed no resistance. Called and had it replaced.
Old May 25, 2015 | 08:12 AM
Pete1122's Avatar
The seller has been above and beyond for my flamethrower injectors. I emailed him the issue, he asked me how many replacement injectors I need and two days latter I had them at my door! I am just waiting on a few gaskets and crush washers and I'll put everything back together.
Doug4320
Mar 24, 2018 10:11 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
karbin
Jul 5, 2015 11:37 PM
