Misfire or normal engine behavior?
Old May 27, 2015 | 02:52 PM
Gamma_Hugo's Avatar
I have a 1994 Toyota Pickup
2WD with a 22re...
So I have a semi new rebuilt engine that I dropped in there last year. I have noticed that there is a slight, but very noticeable jump when the engine idles and when I am driving it.
I have adjusted the valves, replaced the PCV valve and the grommet, set the timing to 5°, and set the idle to 750 rpm and still has that jump/misfire.
So what could cause this jump that I am I think is a misfire?
* New fuel injectors
* New distributor cap and rotor
* New spark plug wires and plugs
Only thing that comes to mind is a vacuum leak somewhere
Old May 27, 2015 | 04:09 PM
skypilot's Avatar
Inspect your camshaft I bet you have a flat lobe or two. Whose cam did you use in the build?
Old Jun 4, 2015 | 12:27 PM
jennygirl's Avatar
Check engine grounds as well. There is a really good writeup here:
https://www.yotatech.com/forums/f116...-guide-194413/
I found a few of my grounds to be totally missing, as well as some of them corroded / dirty. I even added a few more grounds just to be safe. Car starts up with a single crank every time, and engine stutter was greatly reduced. Since you did remove the engine, chances are maybe one of the grounds is not up to speed, or maybe a connection point on the block you dropped in was dirty.
It could also be a dirty alternator connector, it sits in a harsh spot prone to corrosion. Pull the connector off of the back of the alternator, give it a good blast with electrical cleaner, and put a very thin layer of dielectric grease on the connector connections before throwing it back on.
Good luck! Hope you get to the bottom of that!
the1998sr5
15
Jul 14, 2020 08:35 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
Poncho0206
Jul 10, 2015 06:21 PM
wilbertd
Jul 6, 2015 07:39 AM
