codes 25,31,32,24
Old Apr 29, 2009 | 06:33 PM
iselloil's Avatar
codes 25,31,32,24
CEL came on,went off and came back on. 1993 4runner 3.0. Truck runs fine,but cant seem to find the problem,any suggestions?
Old Apr 29, 2009 | 06:53 PM
89silverpu's Avatar
25 could be
AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--AIRFLOW METER OR MAP SENSOR
--IGNITION
--ECU
31 could be
MANIFOLD AND/OR AIRFLOW METER SENSOR SIGNAL CIRCUIT
--AIRFLOW METER/CIRCUIT
--MANIFOLD PRESSURE SENSOR/CIRCUIT
--ECU
32 could be
--AIRFLOW METER SIGNAL (VANE-TYPE)
--AIRFLOW METER./CIRCUIT
--ECU
24 could be
--INTAKE AIR TEMPERATURE SENSOR SIGNAL--OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
--INTAKE AIR TEMPERATURE CIRCUIT
--ECU
I'd start with replacing the 02 sensors then go from there. That's the most common problem it seems.
Old Apr 30, 2009 | 03:35 AM
iselloil's Avatar
Changed the plugs,NGK's and Ngk wires,Toyota Cap and rotor,Air Hog air filter.Put on new muffler and tail pipe, Ran great.Then codes showed up.The check engine light went off, and then came back on.
Old Apr 30, 2009 | 04:15 AM
toyota4x4907's Avatar
Try clearing the ECU and see if they come back on.
Old Apr 30, 2009 | 04:34 AM
iselloil's Avatar
on the 93 4runner, pull the EFI fuse?
Old Apr 30, 2009 | 04:35 AM
BoostinChick's Avatar
You can just unplug the terminal from the battery for about 15-30 seconds.
Old Apr 30, 2009 | 04:45 AM
Indeed. EFI fuse or + battery connection.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
