4runner idle
Old May 5, 2009 | 09:22 PM
interrunner's Avatar
4runner idle
So i got my first car and it is a 1990 4runner v6 3.0 liter auto. IT needed some work so my dad (he knows a good amount about toyotas, used to work on them all the time) and i went to work and took off the air intake and bunch of hoses and stuff and replaced the valve cover gaskets from a slight oil leak. Well the leak is gone and the car works fine it just idles high in park, at about 1200-1400 rpms. when i put it in drive or reverse it goes down 500-800. I was just wondering about an suggestions? or is it supposed to be that way?
I checked under the hood and it said it should be idleing at about 800 rpms.
Old May 5, 2009 | 09:34 PM
Jay351's Avatar
Check for leaks on the vac lines and intake..
Old May 6, 2009 | 07:37 AM
Baja Toy's Avatar
Check your timing first. If that is set right, turn the idler adjuster on the throttle body out 1/4 turn at a time to see if that fixes the issue. If not, check the EGR valve, EGR modulator and all vac lines.
Old Oct 14, 2009 | 10:01 PM
hey what they heck does ISR stand for? like in the ISR mod.
Old Oct 15, 2009 | 06:45 AM
A.Wilson013's Avatar
Intake Silencer Removal, I believe.
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
