HID Question
Old May 4, 2009 | 05:57 PM
Xx_Black-out's Avatar
Question HID Question
Is there anyway to get HID headlights in a 89 Toyota? I've seen these cheapo "H4" headlight assemblies on ebay...but I don't know much about them.
Thanks in advance!
-Nick
Old May 4, 2009 | 06:03 PM
Flash319's Avatar
Get the good glass ones from Hella. I got them for my truck and they work great. There are lots of different bulbs you can put in them. One of the best mods I have done.
Old May 4, 2009 | 06:06 PM
I've searched around a little...but no luck. Where did you find yours? Part # by chance?
Thanks!
Old May 4, 2009 | 06:10 PM
Flash319's Avatar
Search Hella H4.
Old May 4, 2009 | 06:13 PM
Search Hella H4.
StylinConcepts!
Awesome
Old May 4, 2009 | 09:32 PM
space-junk's Avatar
i like the ones that i got from ebay... they have a glass housing too...
with the sylvania silverstars they are pretty bright...
Old May 5, 2009 | 10:29 AM
Jay351's Avatar
You can easily get 'HID's
Heres how, first pick up a set of Hella e-code h4 lenses. They will replace your current housings with a non-sealed beam style.
now go online and pick up a H4 HID kit. PLug it all in and have fun...
Do NOT use regular 'dot' lenses. Their pattern is horrible with that much light output. You will be blinding everyone.
Old May 5, 2009 | 10:44 AM
T-1000's Avatar
Yeah, make sure you have HID compatible lenses and housings to go with the bulb, that what "makes" it.
The bulb alone is pretty worthless, not to mention dangerous because of the glare.
And if you get an "HID" bulb and it has a filament, it's fake. Real HIDs make light with an arc between two electrodes.
Old May 5, 2009 | 05:19 PM
But do the new H4 bulbs/ballasts plug directly into my old 6054 harness??
Yeah, I'm talking about "real" HID lights... Not HID "look"...
Old May 5, 2009 | 06:53 PM
space-junk's Avatar
seeing as tho H4 bulbs fit directly into the plug, id say, yes...
one thing you might wanna do before that is to upgrade the headlight wiring harness with the one that roger brown sells at www.4crawler.com...
idk if the stock wiring harness can supply the amount of energy that the
hid balasts require... just an idea...
Old May 5, 2009 | 07:07 PM
Jay351's Avatar
I thought HID's require less power?
anyways they should be fine
coreyedwards7611
Jan 16, 2016 06:38 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
Edionne13
Jul 9, 2015 01:59 PM
