grinding noise
Old May 4, 2009 | 05:06 PM
dan8906's Avatar
Old May 4, 2009 | 05:41 PM
thook's Avatar
22r/e, I presume?
Mmm....water pump bearing, possibly? Is this with the truck in motion, stationary, or both?
Old May 4, 2009 | 08:48 PM
dan8906's Avatar
in both motion and stationary
dan8906's Avatar
oh and yes 22re
Old May 5, 2009 | 02:55 PM
thook's Avatar
Well, okay..........since the noise appears when it's also stationary, you should put a stethoscope or long screwdriver (handle end to your ear) on different areas of the motor when the grinding is present. And, is it really a grinding, and can you give an example of what is kind of sounds like?
Tank capacity is like 17-18gal. Actually not really sure on that, though.
Old May 5, 2009 | 03:00 PM
dan8906's Avatar
well it sounds to be coming from maybe the drive shaft? i can hear the noise in my cab, and sounds like its under or somewhere below the shifter, and im not really sure on how else to describe the noise. its probably not as bad as a grinding noise but something similiar
thanks for the help,
daniel
abecedarian's Avatar
Clutch in or out would help isolate the trans from the engine too.
Old May 5, 2009 | 03:02 PM
dan8906's Avatar
the noise happens when its in or out of gear, around the same rpm
Old May 5, 2009 | 06:35 PM
Skinsfan6's Avatar
Is the driveshaft not bolted on tight and vibrating with the higher rpms? Just a thought. Look for anything that could be loose really.
Old May 5, 2009 | 06:40 PM
I don't know much about how or where you drive your truck but I rarely exceeed 4000 rpm's unless I'm struggling to hold speed up a hill on the Interstate.
Maybe the grinding or rattle is related to bushings, engine mounts, even the transmission input shaft (you didn't say if it was quiet with the clutch depressed like I asked, only "the noise happens when its in or out of gear, around the same rpm" In or out of gear doesn't mean you had your foot on the clutch or not).
As well, could be the fan clutch, alternator or just about anything that is subject to those high RPM's.
Old May 5, 2009 | 08:54 PM
dan8906's Avatar
sorry i didnt understand, um yes it does it when i hold the cluth down and when im not holding it
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
