locked hubs + 2wd=?
Old May 7, 2009 | 02:35 PM
toyNG's Avatar
locked hubs + 2wd=?
Will I be able to notice a front locker while running in 2wd with the hubs locked? The reason I ask is because I might be able to get a good deal on a used IFS third with 4.88s and a lockright. I didn't really have plans on getting a front locker, but if it's a good deal, I might go ahead and get it.
My understanding is that the locker will be completely transparent when the hubs are unlocked, in either 2HI, 4HI, or 4LO. What I'm wondering is if the locker will be noticeable while running trails in 2HI with the hubs locked.
Old May 7, 2009 | 02:37 PM
85excab's Avatar
yep it will. it will make it harder to turn
Old May 7, 2009 | 04:08 PM
Bobzombie's Avatar
Um NO. It will not help at all in 2wd as the drive shaft is not driving the diff. A lockright is a mechanical locker so it would not even lock in untill it is being driven be the shaft.
If its a good deal then HELL yeah its worth it but it will only work in 4wd
Old May 7, 2009 | 04:13 PM
toyNG's Avatar
ok. This is what I was thinking too.
I know that the locker will lock up when under force from the drivetrain. However, I wasn't sure if the locked hubs would transmit force to the differential, thereby causing the locker to engage. I guess all I wondering is if taking it out of 4wd will effectively eliminate all the undesirable aspects of a front locker, such as limited steering or the self-centering effect.
jaretstuff
Aug 4, 2015 02:08 PM
defrag4
Jul 31, 2015 10:50 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
