So now I have a transmission issue.....
Old May 5, 2009 | 10:37 AM
silverbullet830's Avatar
I know I don't have many posts on here, and i usually don't get a response but i really don't know what else to do. I've had problems with my truck since right after i got it. it doesn't make the power it should. i've been trying to get that sorted out but now i have a much bigger problem. No matter what i do it won't shift out of 1st gear. i mean i can shift the leaver and it goes from park to neutral and reverse and all that just fine but if i start down the road, as i accelerate it just never shifts. the only thing i can say for shure thats wrong with it besides the missing muffler is a bad tps but it was like that before this issue came up. this is my only form of transportation. if i don't figure this out soon i'm screwed. PLEASE HELP!!!!!
Old May 5, 2009 | 10:41 AM
4Crawler's Avatar
Might get ahold of a Factory Service Manual and follow the troubleshooting steps in the AT section.
Old May 5, 2009 | 10:52 AM
T-1000's Avatar
I don't think it will shift at all if your TPS is totally screwed...Or at least if I remember correctly that's what happened when I unplugged mine.
Old May 10, 2009 | 02:03 PM
good to know about the tps. i looked through the fsm troubleshooting guide and it didn't mention anything bout it not shifting out of first. i'll see what happens after i change the tps. thanks for the input guys!
Old May 11, 2009 | 10:14 AM
Matt16's Avatar
Have you checked to see if you have any fluid? Is it clean?
Old May 14, 2009 | 08:50 AM
I've come to the conclusion that its the tps. with it unplugged it shifts early so i have to hold it in a lower gear to accelerate reasonably. if i do this the shifts feel fine, and no strange noises or anything. with it plugged in it doesn't shift at all. ordered a tps a minute ago. also noticed a loose wire on the back of the plug for the sensor. anybody know how i would go about replacing this plug? the idl circuit of the tps tested bad so i know i needed one anyways but i'd like to fix this plug when i replace the sensor.
TheBFA
Feb 15, 2020 06:55 AM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
briholt
Sep 20, 2015 10:26 PM
