Engine died while driving!?!
Old May 6, 2009 | 03:33 AM
jbird196's Avatar
Exclamation Engine died while driving!?!
While driving home from the store last night in the rain, my engine died while accelerating up a hill and now it wont retart. I have a 94 pickup with a 22re. Any ideas on what the problem could be and tips would be greatly appreciated. Thank you!
Old May 6, 2009 | 03:50 AM
DIHOWARD's Avatar
Gas or timing belt
Old May 6, 2009 | 03:55 AM
DIHOWARD's Avatar
maybe check EFI fuse
Old May 6, 2009 | 09:11 AM
4R$pit's Avatar
With copper wire and ignition off, try jumping the B+ to Fp terminals in diagnostic box. Then try to start. If running OK then problem probably the "circuit opening relay". Located by itself, above ECM, attached with 5-wire connector. Expensive at dealer, anyone know where to get aftermarket?
Old May 6, 2009 | 06:30 PM
sb5walker's Avatar
If jumping B+ and FP gets it going, you can check the COR:
http://personal.utulsa.edu/~nathan-b...38circuito.pdf
A bad fuel pump switch in the vaf meter will also cause COR not to operate:
http://personal.utulsa.edu/~nathan-b...33volumeai.pdf BTW, typo in troubleshooting step 1(b): B & FC SHOULD have continuity (but will have some resistance due to coil winding).
If jumping B+ and FP doesn't get it going, your coil may have died. Check both circuits:
http://personal.utulsa.edu/~nathan-b.../4onvehicl.pdf
Pull your igniter connector and make sure it isn't filled with water...
Make sure the igniter ground is good, and check the distributor connector, and signal rotor & coil.
Check the IGN fuse in driver side fuse box. Make sure the fuse is hot when ignition is on, otherwise ignition switch may be bad.
Old May 6, 2009 | 06:34 PM
abecedarian's Avatar
since it was raining when it died, check the distributor cap for moisture and check all the plugs around the ignition coil / igniter for water / condensation.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
