HELP ! grinding sound from right front tire area
Old May 7, 2009 | 03:20 PM
4runningforlife's Avatar
When i turn right, there is a loud grind coming from my front right tire. This also happens when i hit a bump. While drving slow it isn noticable, but when over 20 mph it is very. i thought it was my brake pads or rocks in them, but replaced and no luck.
Old May 7, 2009 | 03:40 PM
Tubbyfatty's Avatar
Alot of things come to mind, but i cant remember the names of em at the moment.
Bushings? uhh...
Hopefully someone will suggest stuff haha.
Bump.
Old May 7, 2009 | 04:01 PM
Bobzombie's Avatar
I was thinking brake pads stuck on the slide pins but you said you changed the pads? Did you clean the pins?
Does this sound change when you hit the brakes?
Backing plate touching? Wheel hubs? bearings? Cv joint?
thats really all it could be if it is from the front end
Old May 7, 2009 | 04:04 PM
toyota4x4907's Avatar
what about the ball joints?
Does the "grinding when going over a bump" happen when you're going straight and you hit a bump or when the wheels are turned? Cuz it could be the steering stops..
Old May 7, 2009 | 08:21 PM
so the grinding noise almost always happens when turning right or when i hit a bump while turning. however, sometimes when only hitting a bump (more rare). also, when i changed the brakes, i do not distinclty remember cleaning it, but the sound doesnt change with pressure.
Old May 7, 2009 | 08:37 PM
racingcameron66's Avatar
dude, my truck just started doing the same thing... someone told me that it may be the rackandpinon bushing so i looked at it and it was worn out soi got one of thoes and ill let you know how that works out for me
Old May 7, 2009 | 08:40 PM
jpmountainboy's Avatar
are your hubs unlocked? maybe your cvs are toast and your in 4 wheel. my hubs broke and they kept em locked even when unlocked and it ruined mine. you can tell if you jack up the tire and turn em unlocked...if the cv moves you got trouble in yotatown
Id pound back the backing plate a bit like bobzombie mentioned just to make sure its not that, its happened to me after changing pads.
Old May 7, 2009 | 10:13 PM
Pre-Tacoma's don't use rack and pinion steering
Old May 7, 2009 | 10:42 PM
my trucks not a pre-runner(if thats what your talkin about), and he never said what kind of truck his was so.....yea
Old May 7, 2009 | 10:52 PM
ha. I know yours isnt. He posted in the 86-95 trucks/4runners. I was just saying that if you change your bushings and it clears up your noise doesnt mean it will help him
Old May 8, 2009 | 03:38 PM
i just packed my berring and it stoped so i would try that
Old May 8, 2009 | 04:42 PM
86Toyrunna's Avatar
to me it sounds like toasted wheel bearings.. either way id get out the de-greaser and brakeclean and scrub that whole area down and look for anything with visable sings of wear.. if none found, open up the hub and start looking internaly
BushPig
Oct 29, 2022 06:26 AM
djpg2000
Nov 11, 2020 04:56 AM
Sep 4, 2015 09:27 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
