What's a good SWITCHED power source?
Old Apr 29, 2009 | 05:29 PM
qdude79's Avatar
I have my e-fans wired directly to the battery as a means of avoiding the tremendous draw down of having it wired back into the fuse panel. The problem is, my fans always kick on for a few minutes after parking. This doesn't cause any immediate problems, but leads me to believe that having that drain every time I park will eventually lead to premature battery failure.
Anyone got a source for switched power that'll handle the ~25amp draw without burying my stock Fisher Price alternator (soon to be upgraded, by the way)?
TIA
Old Apr 29, 2009 | 05:45 PM
4Crawler's Avatar
Best bet would be to add a relay that you trigger off of switched power and then run it to the battery, via a fuse or circuit breaker. But the fan should only run once or twice for a short time after shutting off the engine to cool the radiator down. If it is running more than that, might have some other problems.
Old Apr 29, 2009 | 05:58 PM
qdude79's Avatar
Thanks Roger... thought about that, but I've never done it before. As I understand, I'd just need to get about a 30 amp relay, with the trigger wire going back to the fuse/junction box?
Old Apr 29, 2009 | 06:11 PM
4Crawler's Avatar
Some links below:
http://www.aaroncake.net/rx-7/efaninstall.htm
http://www.lextreme.com/relay.html
and more...
http://www.google.com/search?q=wire+relay+for+fan
Old Apr 29, 2009 | 10:29 PM
turborich's Avatar
He's 100% right. Use a relay & the correct sized wire & you will be good to go. I relay & fuse just about everything & never had a problem.
Jun 1, 2021 01:51 PM
skoti89
Jul 8, 2015 12:05 AM
Gamble_STi
Jul 7, 2015 07:54 PM
cyclist231
Jul 7, 2015 12:56 PM
colinmil
Jul 6, 2015 04:03 PM
