Brake line leak
Old Oct 24, 2009 | 05:39 PM
ltjman22's Avatar
Brake line leak
1995 Pick-up, 4WD, Manual, 22RE
Anyone know where I can find the brake line part right beside the gas tank.....It's leaking like a seive when I step on the pedal. I can't find it anywhere online, but have not called the dealer yet?
Thanks!
Old Oct 24, 2009 | 05:48 PM
pwd's Avatar
pwd
Your looking for the exact part number/a place to order it?
Use this place for finding the exact part number:http://www.toyodiy.com/parts/
And I have purchased from: https://www.1sttoyotaparts.com
Just a note, if your going to replace it with a factory line, you may have to drop you gas tank since its in a poorly accessible location.
Old Oct 26, 2009 | 04:52 AM
ayoung101's Avatar
the brake line "part"? are you talking about an actual brake line, or are you talking about the LSPV (load sensing proportioning valve)? the LSPV looks like a little block with i think 3 brake lines going in to it and then a steel rod that goes between it and the axle. is this the part you're talking about? if it is, i found a used one on yotatech when mine went bad. if you're just talking about a brake line, any auto parts store will have one that will work.
this is an LSPV:
Sleaker
Aug 26, 2020 06:03 AM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
