Rear diff, headers, blower and step-bars.
Old Oct 22, 2009 | 07:38 PM
Tyson0317's Avatar
Hi guys,
I am looking to do a few upgrades on my '94 4x4 pickup (V6, 5spd).
# 1 I want to get the rear diff upgraded to a TorSen unit. I called Randy's Ring and Pinion and the service desk told me about $700 for parts and labor. Does this sound right? It cost $550 a few years ago for my F150 and that is a bigger diff...
#2 I am looking to upgrade the intake and exhaust on the truck (as both look to be hella restrictive). I heard that the head gasket failures on my 3.0L V6 are likely caused by poor header design. Gasket failures aside, it does not take a scientist to see that the stock header is not designed with performance in mind. What's a good way to go with an aftermarket header (preferably equal-length piping for each cylinder).
#3 The intake path also leaves much to be desired - I am looking to simplify the sytem with straighter piping, but I also thought about kicking on a little electrical blower - noting major, only 2-3PSI at WOT. Has this been done on these rigs before? Can the stock ECU and injectors handle the additional flow?
#4 I am looking for step-bars to put on the sides of the truck to serve a dual purpose, both as a step, but also to protect the body when climbing rock and as a convinient jack point (so they have to be sturdy). Any suggestions on affordable factory-made units, or should I just make/weld some myself?
Old Oct 22, 2009 | 08:32 PM
Jay351's Avatar
1. So you want a limited slip rear end? Try a detrioit soft locker...
I run a cheap lockright rachet/autolocker.
2. the crossover design is indeed pretty bad, how the exhaust wraps around the back of the drivers head and dumps backwards into the drivers manifold.
Best kit I can recomend is the LCE street header kit. Its pretty pricey but you get what you pay for. Most people will recomend this kit over any others...
3. Id do a "ISR" mod. Then you could possibly throw a larger AFM on there (search for the year/model afm that works) Don't bother with those electric blowers... not worth it.
4. Search Sliders Available at lots of places like trailgear.com marlincrawler.com etc...
Old Oct 22, 2009 | 08:44 PM
toyota4x4907's Avatar
http://www.nissanclub.com/forums/off...ric-turbo.html
Electric blower fail
Old Oct 23, 2009 | 08:04 AM
Tyson0317's Avatar
Ya that was a good laugh... The guy obviously didnt know what he was doing. Number of major flaws in his design. However, I have seen the idea used well before.
a. You need a flap that will let the engine take unrestricted air when the 'blower' is not on. Sucking through the blower is very restrictive.
b. The switch should be on a WOT sensor or an under-pedal veriety.
c. The puny fan he had mounted is a joke - what I have seen people do is use leaf blowers. By my math at redline, the engine will suck just under 700CFM. There are blowers out there that will push 1200+
d. Some form of boost controll needs to be installed as at lower RPMs the boost may be too much. This can be done via a pressure-activated exit for excess air (I bet a Blow-off-valve can be set up for the purpose).
In any case, I was just tossing the idea out there... The engine on my Toyota is so surprizingly gutless, that sometimes I get crazy thoughts in my head... I have owned many cars with 2.8-3.1L 6-cylinders - my truck is BY FAR the most sluggish...
Old Oct 23, 2009 | 08:06 AM
Tyson0317's Avatar
What is the 'ISR Mod' ?
Old Oct 23, 2009 | 11:34 AM
Jay351's Avatar
Search. The function is there to help.
Intake
Silencer
Removal
Mod
Its been covered 10000x times There was a big thread dedicated to it..
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
jaretstuff
Aug 4, 2015 02:08 PM
scottyg486
Jul 19, 2015 05:34 PM
msane99
Jul 17, 2015 10:13 AM
