22RE Stumble
Old Oct 22, 2009 | 12:38 PM
A.Wilson013's Avatar
22RE Stumble
When I let off my accelerator to maintain a speed, say 30mph in 3rd gear, my engine noticably stumbles...
Any idea what would cause this?
Alex
Old Oct 22, 2009 | 07:19 PM
Anyone...?
I am not sure if it is related, but I cannot believe it's not. Last night Kiyobrown and I swapped intake/battery and put an 82 Supra MAF on... Now this is happening.
Help, please.
Alex
Old Oct 22, 2009 | 08:21 PM
myyota's Avatar
The best thing to do is go back to the stock se up and see if the problem stops, if it does then you have found the problem.
Old Oct 22, 2009 | 08:42 PM
I appreciate your response, but I really don't have time to do that...
What could have happened during the swap that would cause this? Could it be that I am running too lean or rich? Could it be from the exhaust leak that I found?
Thanks a lot,
Alex
Old Oct 23, 2009 | 01:25 PM
No other ideas?
Alex
Old Oct 23, 2009 | 03:21 PM
abecedarian's Avatar
So... if you are accelerating, then release the throttle slightly to maintain speed, the engine stumbles? What I mean is that you're not letting the throttle close when transitioning from acceleration to cruise?
How are your engine mounts?
Old Oct 23, 2009 | 03:34 PM
I may be letting it close. Sometimes while driving I will just let off the gas completely. I am noticing that I am starting to feel like an idiot. Would my driving style be causing this? haha...
I believe my engine mounts are fine. I will have to check to make sure.
Thanks for your reply,
Alex
Old Oct 23, 2009 | 03:46 PM
If the mounts are weak, they could let the engine shift when going from accel to decel and that could be felt like a misfire or stumble... and the trans-mount can do so as well.
Another thing to check is the dashpot on the throttle body. If you rev the engine up to 2000 and hold it for a second, then release the throttle, the dashpot should hold the throttle slightly open for a second or two before letting it close. If the throttle suddenly closes, the AFM could slap shut and cut off fuel which could be felt as a misfire.
Old Oct 23, 2009 | 04:26 PM
kiyobrown's Avatar
How bout that huge hole in your muffler? Or the back window that just won't make it up all the way? I got it..... Its the new hubs!!
Don't talk crap about my new phone!!!
Weird, Abe brought up the dashpot. Maybe your blue dashpot could be causing it all. Guess there is more crap to check on your rig, huh?
krimsonone
Sep 13, 2024 09:33 AM
crammit442
7
Nov 29, 2017 12:30 PM
Phantez
Oct 30, 2015 04:46 AM
mikeyd6789
Aug 4, 2015 11:51 AM
pyramid
Jul 30, 2015 10:05 AM
