22RE runs weak after rebuild
I finally got everything hooked up on my '94 22RE and tried to start the engine. It cranked a little while, but it finally started up, and ran quite poorly. The engine would not increase its speed, no matter what I did with the throttle. It ran for about 10 seconds, then dies. What could this be?
I eye-balled the timing at 0 degrees just to start it. I also cranked the motor for about 20 seconds before I put the plugs in, in order to get some oil pressure built up. What I figure is maybe I have some of the injectors plugged in wrong, this would have put some unburned fuel in each cylinder prior to putting in the plugs, allowing it to start... but then remain unresponsive to an increase in throttle???
What do ya guys think? And if I'm right, how do I know which injector gets which plug?
It sat for 2 months while the motor was out, how do I check for fuel pressure?
"Did you short the diagnostic box for the timing?"
I don't even know what this means, please explain
Well, yeah I guess. It only ran for about 10 seconds, but had a real low idle and sounded absolutely gutless. I didn't even have enough time to check the timing. It almost sounded like a mild exhaust leak, not air escaping...just kinda thump thump thump
How can I tell the correct order for the injector plugs?
Also, when plugging everything together, the injector plug for cylinder no. 1 ended up being a different color and shape than the rest... or so that is how I hooked it up, based off other member's pictures I was able to see that the wire plug for the first injector was coming from a different location on the harness, so I switched it to that one- but it is a different color and shape from the rest of the injector plugs(it does hook up to the injector though).
Man, now that I think about it, that doesn't sound right??
I can definately see how # 3 and 4 can get mixed up; they come out in the same spot, and look to be about the same length
# 1 and 2 should be straight forward though; they would only reach their specific injector
also, they should ALL be the same color; the light gray pictured here. UNLESS someone in the past, for whatever reason, decided to so some modifying...
Also check your distributor and make sure as it slides in the rotor ends up pointing to number 1 plug on the cap
Puts the engine in base timing (no spark control)
That is when you are supposed to set timing.
To check if you have other issues effecting the fuel pump you can run it like this for testing purposes........I've heard of people leaving them in and driving instead of fixing the problem but I wouldn't recommend it.
the little gray box next to the fuse box on the passenger side fender jump te1 and te then use a timing light on the crank mark and set it at 5 to start(stock setting) and adjust as needed.
When I rebuilt my 22re I had a similar problem. It turned out to be the flapper inside the air flow meter was stuck open, causing it to run very rich. I would also check to make sure your spark plug wires are in the correct order.
YFZsandrider, my truck is a '94 and my injector plugs are the same as yours (all green except #1 is smaller and gray).
When I put my 22re back together my engine exhibited similar symptoms as to what you describe in your original post. It's hard to set timing when the engine dies after 10 seconds.
In my case I had installed the distributor off by 1 tooth. It's tough to eyeball, but I would try re-installing the distributor and moving clockwise by one tooth.
Assume that if this is the case (and not some other problem) the engine should idle even if the timing is off a few degrees one way or the other. Once you get it to where it will idle and not die on you, then set your idle speed, then jump your terminals, then adjust your timing.
Good luck!
Good luck!
