Help Diagnose This Noise (engine)
Old Oct 19, 2009 | 10:39 PM
GodwinAustin's Avatar
I think it may be the fan clutch, but Im not sure. This is the noisiest 22re I've owned. Any ideas?
http://s53.photobucket.com/albums/g7...t=P1000507.flv
Old Oct 19, 2009 | 10:59 PM
raydouble's Avatar
Hard to tell what the sound is with my crap computer speakers.....
Have you inspected the idler pulley?
Also spin the fan blades to check for sound and wiggle the fan to see if there is play in the clutch hub.....
Then you can take the belts off and spin everything, to see if anything is making noise.
Old Oct 20, 2009 | 01:18 AM
pruney81's Avatar
power steering pulley?
Old Oct 20, 2009 | 01:34 AM
turboboost's Avatar
Take off each belt one by one. If the noise goes away, you've found your problem.
Old Oct 20, 2009 | 08:47 AM
well I'm not running any power steering at the moment and so the belt is not on the tensioners/pulleys could it still be making noise?
I figured pulley/bearing noise as well, Is there something like belt grease you can spray on the pulleys to quiet them down, something like belt grease? Or do I need to replace the bearings themselves?
Old Oct 20, 2009 | 08:49 AM
seanmearse's Avatar
Put a power steering belt on it, and remove the alternator belt, see if the noise stops then.
Old Oct 20, 2009 | 09:02 AM
pruney81's Avatar
my power steering pulley is a little noisy, it's not really a problem till the bearing goes then you have to replace it obviously, you could try oiling it i guess
Old Oct 20, 2009 | 09:03 AM
so everyone seems to agree that this is belt/pulley noise of some kind?
Old Oct 20, 2009 | 09:30 AM
seanmearse's Avatar
More than likely, reason I mention it, mine is howling too. in my case its the idler pulley, its loud.
Old Oct 20, 2009 | 09:35 AM
pruney81's Avatar
how's your power steering fluid level?
Old Oct 20, 2009 | 09:45 AM
seanmearse's Avatar
Mines fine. He doesnt have the power steering belt on.
Old Oct 20, 2009 | 09:49 AM
pruney81's Avatar
Oh, right I just re-read that he said he had no power steering. I asked that cuz mine was making noise on cold starts a few weeks back and I noticed the fluid was a little low, topped it off and it's quiet now
Old Oct 20, 2009 | 09:56 AM
seanmearse's Avatar
No worries. Could even be the water pump. If its all corroded and full of deposits, it will definately make some noise.
Old Oct 20, 2009 | 01:09 PM
I may end up checking the water pump as well. Its something as the other 22re engines I have had sound kind of like diesels at idle, this one is just loud.
Old Oct 21, 2009 | 05:46 PM
Also when the truck warms up, the exhaust starts sputtering. Any ideas on this?
Yota.Jay
Jul 23, 2015 08:08 PM
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
