86 22rte. trans reverse wire question
Old Oct 23, 2009 | 12:14 PM
perpetrat0r's Avatar
Question 86 22rte. trans reverse wire question
hi, should i be getting a reading from the reverse wire when i put it in reverse? cuz im getting nothing. and what is that wire supposed to connect to? is it a signal wire to a relay or should it be a 12v output? any kind of wire schematic for the truck would be awesome! even if its not for this particularly. thanks again for the help.
Old Oct 23, 2009 | 05:52 PM
bugs1961's Avatar
On my '89, power to the reverse lights is from the Gauge fuse and has 12v to the back-up switch anytime the ignition switch is "on". There is no power in the "off" or "acc" positions.
According to my FSM, on floor shift trucks there is no relay--direct power from the fuse. My truck has a black/orange stripe wire from the fuse to the back-up switch on the transmission and a red/white stripe wire to the lights.
Old Oct 24, 2009 | 03:55 PM
so where does the wire harness run? red/white wire comes from lights, i assume they come together not far from there, then heads up to the fuse box. where can i tap into them to to run a manual switch?
btw. the last post was very useful info. thanks
Old Oct 25, 2009 | 09:07 AM
bugs1961's Avatar
If you want to put in a manual switch to turn on the reverse lights I think it would be easiest to tap into the wire at the back-up switch on the transmission. You could run the wires up through the shift lever boot and mount a switch there or run the wires under the carpet to the dash and put a switch somewhere there.
If your OEM back-up switch is bad, they can be replaced for about $40 from the dealer. I just put a new one in my truck due to oil leaking out through the housing.
Here is a good site to find part numbers for anything on the truck. http://www.toyodiy.com/parts/ Put in your VIN and get vehicle-specific part numbers to take to the dealer.
Take care and good luck,
Bugs
Old Oct 25, 2009 | 12:22 PM
i dont quite understand the back up switch enough to tell if it is bad. also, since the truck had a manual trans swap i believe it is the G58 trans. so its hardto search parts with my VIN. and the wire is not connected to anything. i see no other wires anywhere, suggesting where it is supposed to go. a wiring diagram of reverse wire and lights would be so greatly appreciated, and much easier for me to understand.
KBar
Jul 13, 2015 06:01 PM
88yodabasket
Jul 13, 2015 01:32 PM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
Jnkml
Jul 6, 2015 01:20 PM
