Fuses melting?
Old Oct 24, 2009 | 10:36 PM
Jory121's Avatar
Fuses melting?
Anyone having any problems with their fuse melting thats goes to the taillights and dash lights?....ya well mine is shorted somewhere and melting fuses, any suggestions?
87 4runner 22re
Old Oct 24, 2009 | 10:47 PM
Agent Orange's Avatar
Melting? Wow, sounds like a hard short. Take a look at your wiring and see if any of it is bubbled or discolored more than the surrounding wiring. If it's pulling that much amperage and heat to melt a fuse, it should be making itself known the the wiring as well. If you can, also check continuity.
Old Oct 24, 2009 | 10:59 PM
Jory121's Avatar
ya i found the wire supper crispy...are they hard to re-wire
Old Oct 24, 2009 | 11:02 PM
Not really. Just need to see where it's shorting at and rewire past that. So follow the crispy wire and see where its doing it. To do a good job, a simple soldering iron and new same gauge wiring and electrical tape can do the job.
Old Oct 24, 2009 | 11:14 PM
Jory121's Avatar
cool ill give it a shot tommorow in the light thanks!
Old Oct 27, 2009 | 07:36 PM
YotaTron88''s Avatar
Your running WAY to big a fuse for it to melt and turn the wire crispy. It's suppose to blow before the wire melts and catches a fire...thats there purpose
Old Oct 27, 2009 | 07:39 PM
camo31_10.50's Avatar
the ole boy is right..lol..my Amp fuse by the battery would blow..so in order for it to work on cruise night..i put in a 5amp bigger fuse..problem solved..lmao..although it melted it after a while..but nothing was harmed as far as i know..
it could just be a loose connection somewhere..so check all of your connections bud!
Old Oct 29, 2009 | 12:21 AM
Jory121's Avatar
thanks all....its melted all the way up to the harness, this sucks
Old Oct 29, 2009 | 02:12 AM
milehigheric's Avatar
Lesson learnt I think...Only use the rated fuse.
Happy rewiring
RyanJ989
11
Apr 7, 2021 09:41 AM
bryan34w
12
Sep 30, 2015 02:50 PM
Scotttekoch
Sep 28, 2015 10:30 PM
JPV
Sep 28, 2015 03:15 PM
Rcbc92
Sep 26, 2015 03:00 PM
