O2 sensor question...
Old Oct 22, 2009 | 06:50 PM
YFZsandrider's Avatar
Does the O2 sensor being plugged in really affect the way the vehicle runs... primarily it's emissions output?
Old Oct 22, 2009 | 09:20 PM
milehigheric's Avatar
I am not using stock ECU so I can't say for sure, but I am pretty sure the ECU will retard the engine without a correct 02 sensor
Old Oct 22, 2009 | 09:23 PM
nv4runner's Avatar
The computer will also interpret the low O2 sensor signal as the exhaust containing too much oxygen, so it will make the fuel mixture really rich... something I'm fighting right now (13-15 MPG and code 25).
Old Oct 22, 2009 | 09:24 PM
bugs1961's Avatar
Yes. The computer uses the feedback from the O2 sensor to adjust fuel metering. While the sensor does affect emissions indirectly, the primary purpose is to allow the computer to enrich or lean the fuel mixture to allow complete combustion. Without the O2 sensor, the computer operates in open-loop mode (a warm-up and back-up mode) and a preset amount of fuel is injected rather than the amount actually needed. The engine will run rich or lean most of the time, and likely very poorly.
moparbay
Mar 10, 2023 03:50 PM
jb451
7
Oct 7, 2022 06:58 AM
Kreedy1
Sep 8, 2015 06:33 PM
zz_denis
Sep 6, 2015 03:43 PM
moparbay
Sep 3, 2015 12:48 PM
