Manual Transmission Options
Old Oct 23, 2009 | 10:22 AM
Xiphos's Avatar
Hey guys, my auto tranny is going out in my 4runner and I am looking to swap it to a manual.
What are my options as far as what trannies I can get for it? So far I've found the R151R transmission (but I've heard those are hard to find), and the stock W56-B transmission. What other transmissions will mate up to my 86 4Runner? If you could give more than just codes, such as what cars they came from, that'd be great.
I heard the celica has a tranny that would mate up? I've had a hard time finding much information.
Also, what are some good clutch/flywheel companies? Do most use ClutchMaster?
Thanks!
Old Oct 23, 2009 | 10:40 AM
toyota4x4907's Avatar
22re or 3vze?
then your signature says '86, so I'm assuming 22re...
Lots of people use MarlinCrawler clutches
Old Oct 23, 2009 | 10:43 AM
Xiphos's Avatar
Yup, sorry. 86 4Runner. It would be a 22re.
Old Oct 23, 2009 | 11:01 AM
RustBucket's Avatar
With the 22re bellhousing I believe you are limited to a W56.
Old Oct 23, 2009 | 12:14 PM
Xiphos's Avatar
If this is true, what models/years came with the W56?
Old Oct 23, 2009 | 01:18 PM
mel63's Avatar
Try this link. Has helped me a bunch when looking for a replacement trans.
http://www.4x4wire.com/toyota/faq/parts
Old Oct 23, 2009 | 01:26 PM
Xiphos's Avatar
So based on that link my only option for a manual are 4runners and pickups from 1985 to 1995 correct?
W56
1985-1995
22RE
25 1/4"
Top (85-88)
Forward (89-95)
Front seal retainer uses 7 bolts.
Old Oct 23, 2009 | 02:14 PM
Windsor's Avatar
Most likely correct.
FWIW, the "top" vs. "forward" refers to how the transmission and xfer case mates up. (Well, technically it refers to how the xfer case takes the shifter, use the search box to find the juicy details).
If you get the xfer case as "part of" the transmission when you buy, you won't need to worry much about it.
If that's not possible you need to pay attention to top- vs. forward-shift (trans and xfer case need to match).
Old Oct 23, 2009 | 02:23 PM
Windsor's Avatar
ah-ha. There's a pic on that 4x4wire.com page.
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
HookahRoo
Jul 20, 2015 07:06 PM
Poncho0206
Jul 10, 2015 06:21 PM
