Pictures of camber adjust bolts 91 pickup? Anyone
Old 10-22-2009, 04:19 PM
SAMSON661's Avatar
Can someone pls put up pic of camber adjustment bolts plz my camber is bad and I don't wAnt to waste tires
, 91 pickup 2wd
Old 10-22-2009, 04:48 PM
nv4runner's Avatar
According to Alldata, the 2wd uses shims.
"CASTER & CAMBER
2WD
Caster and camber are adjusted by increasing or decreasing the number of shims between upper arm shaft and frame mounting surface. The thickness difference between front and rear shim packs should not exceed .16 inch (4mm)."
The 4wd trucks and 4runners use adjusting cams mounted in the control arms.
Old 10-22-2009, 05:19 PM
Kiroshu's Avatar
take it to a shop for an alignment. You will never get it right playing with it at home.
Old 10-22-2009, 08:31 PM
SAMSON661's Avatar
I took it to the shop and they said they couldn't do it, I think I fixed it I just had tbs so cranked and I tuned them down a bit so I get a little rub but not much and tires r strait
bigjstang
08-25-2021 12:41 AM
Regency
20
01-03-2020 07:43 PM
truckmike26
10-26-2015 05:10 PM
God's Bounty Hunter
07-08-2015 12:54 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: Pictures of camber adjust bolts 91 pickup? Anyone
