22re fresh top end, now some problems?!?!
Old Oct 20, 2009 | 06:19 PM
whitebullet3's Avatar
I bought a 1991 2wd 22re pickup a while back and it was supposed to have been just freshly rebuilt. Long story short...got the truck drove it 3 days then it wouldnt start. After tearing down and searching for the problem, it had sat forever and had an inch thick of goo in the gas tank, had to get another tank, it was uncleanable lol, head was resurfaced, installed new injector seal kit, had injectors tested, new headgasket, basically rebuilt the top end myself. Now its back together and the valves are super loud, im a diesel mechanic and honestly this thing sounds like a little perkins, anyway now it has some white smoke when u rev it up, but clears up going down the highway, and also when i hold the fuel pedal steady and low rpm it idles up and down on its own. sorry so long, anybody got any ideas? thanks guys
Old Oct 20, 2009 | 06:22 PM
also i forgot, i put a new timing chain, metal guides, both sprockets, all new valves, cheked and micrometer'd everything. Pulled each plug wire off, idle goes down on each cylinder.
Old Oct 20, 2009 | 06:27 PM
olharleyman's Avatar
set your rockers at 7intake 9 exhaust that will quite it down and make it run better
the white smoke is normal for a few minutes after the rebuild just clearing the oils and such from the greese on your hands putting back together
Check your throttle position sensor may need cleaning or replaced
Old Oct 20, 2009 | 06:32 PM
92 TOY's Avatar
Hey OLHARLEY>>>>>how are ya?
WHITEBULLET......the only other thing I was thinking (in my humble newbie . novice opinion) is how familiar are you with the 22re??
My injectors are nosiy buggers and I know I've read that it a very common and benign thing. But, since it seems you have a boat-load more experience than me, I will say that if you say it is the valves, it's the valves, but just I know the injectors are very loud.
my 2 cents.
alright will check those things, how long should the white smoke last? I have drove it for probably a total of an hour and a half total since the rebuild.
Old Oct 20, 2009 | 06:34 PM
i am familiar with the 22re valve train, this is my 3rd one, and i have another one right here now, its super quite and this one is unbelievably loud, ive heard some loud 22re's but not like this. and it wasn't this loud when i bought the truck and it hasn't been driven 200 miles since then b/c its been apart the whole time lol
Old Oct 20, 2009 | 06:36 PM
ya'll really reply quick, i really appreciate it!
Mine only smoked for about 2 mins.
doin good 92 been checkin in on your rebuild did you ever get everything figured out?
Old Oct 20, 2009 | 06:40 PM
92 TOY's Avatar
just got home from work , all wound UP!!!!!!!!!
OLHARLEY is WAYYYYYYYY ahead of me on skills, just thought that if you hadn't had your head next to a running 22re before, it would be alarmingly loud. but sounds like you've got a grip on that, so I don't know, try what OLHARLEY said......i don't even understand what he said. LOL!
This will quite it down quite a bit mine sounded like a man for a couple days till I reset them to this now it's quite beyond belief
Old Oct 20, 2009 | 06:41 PM
92 TOY's Avatar
OLHARLEY ,,,,thanks.......with work I disapear a chunk of days at a time but I was pumped that I got that bolt off and can still count to 10 and still have all my teeth.
Old Oct 20, 2009 | 06:43 PM
92 TOY's Avatar
he got that from ENGNBLDR.....just busting ya OLHARLEY........you are the new spokes-model for him.
Old Oct 20, 2009 | 06:44 PM
Originally Posted by 92 TOY
OLHARLEY ,,,,thanks.......with work I disapear a chunk of days at a time but I was pumped that I got that bolt of and can still count to 10 and still have all my teeth.
good deal now on to the fun stuff
Old Oct 20, 2009 | 06:46 PM
yeah tomorrow im gonna re-adjust the valves and see how that does, do any of ya'll know where the best place to get the metal washers for the fuel banjo bolt and the cold start injector, none of the places i get my parts from have the size i need. ?
abecedarian's Avatar
If the valves are set properly .008" intake .012" exhaust (hot), .007" / .010-.011" exhaust cold and they still rattle, the valve stems tip(s) may be pitted where the adjusting screw impacts it and/or the rocker shafts/rocker arm bushings may be worn and adjusting the valves won't clear that up. That doesn't mean it wasn't rebuilt, just that if it was, the rocker arms and/or valves weren't replaced.
White smoke, eh? White like coolant or like white/blue/grey like oil? If it's the first case, could be a small coolant leak in the intake manifold gasket. Latter case could be valve seals, pcv system or....
The hunting engine speed may be caused by valve adjustments, which would explain the noise as well, or may be a vacuum leak somewhere.
Old Oct 20, 2009 | 06:49 PM
92 TOY's Avatar
we just went through this last week with anither member, I think he went with the dealer. I did see them on summitracing.com and "earl's" plumbing? I think? earl's was listed on both summit and holley.com (as in the carbs)
Old Oct 20, 2009 | 06:50 PM
All the valves and seals were replaced, and its kinda white like oil.
92 TOY's Avatar
can't spell 2nite...sorry.
Old Oct 20, 2009 | 06:55 PM
are they crush washers?
Okay. You might try capping off the PCV connection to the manifold and the PCV fresh air from the throttle body or manifold (depends on year) and seeing if that alleviates the smoke problem.
It also may be time to do an oil change.
