OBDI Code 11
Old Oct 23, 2009 | 08:41 PM
A.Wilson013's Avatar
OBDI Code 11
So, I have this code.
It's listed as Switch Signal, and ECU/ECM.
What in the world could this mean?
Thanks,
Alex
Old Oct 24, 2009 | 05:03 AM
thook's Avatar
http://www.off-road.com/toyota/tech/codes/
Loss of power supply to ECU through either the ignition circuit or the main relay circuit direct from the battery.
What seems to be the symptom/s you are dealing with?
Old Oct 24, 2009 | 03:10 PM
MudHippy's Avatar
You should also read through this thread.
https://www.yotatech.com/forums/f116...e-nuts-186678/
Same code from that era OBDI system, the 88 3VZE(no code 11 for later models). The code description is identical for both engines(3VZE & 22RE/RTE). So it may be of some help in finding what's causing your code 11 conundrum.
Good luck!
No, I haven't gotten to my VSS yet, if your curious.
Yes, I still have code 11 syndrome!
Old Oct 24, 2009 | 03:28 PM
Kiroshu's Avatar
check make sure ur battery and alt are in good condition and working.... check ignition swtich and wiring make sure its not all buggered up. check the main relay for proper resitance and enrgise for proper volage and or clean contacts in relay.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
