1986 r22 no inyec
Old Dec 22, 2018 | 11:05 AM
Ricue's Avatar
1986 r22 no inyec
I bought an old 86' 4x4 22R it was no starting . I change the fuel pump and clean the gas tank. Then run very good. After a week there is not signal in the main inyectores, only ligthing in the warm up inyector. Seems like short circuit. I all ready probe the main arnes. Fuses and the EFI and FUEL PUMP relay is ok. The spark plugs fire good.
I will appreciate any help.
Thanks.
Old Dec 22, 2018 | 10:31 PM
RAD4Runner's Avatar
Originally Posted by Ricue
...After a week there is not signal in the main inyectores
What makes you know that there is no signal? How did you look for signal?
..only ligthing in the warm up inyector.
What is a warm-up injector and where is the light?
How did you find the short circuit?
I all ready probe the main harness.
How did you probe the main harness?
What equipment did you use? What setting?
What were you looking for?
What did you find?
What did you NOT find?
How did you verify that the fuses, the EFI and Fuel Pump Relay are good?
How could you have an EFI relay on a 22R carbureted engine?
Ricue
Dec 22, 2018 10:57 PM
psm6
Oct 6, 2011 04:50 PM
haydukelives
Sep 23, 2011 04:03 PM
carb85
Dec 6, 2009 07:30 PM
torchman
Jan 12, 2009 06:12 PM
