Sponsored by: CARiD
ticking r22
Old Sep 22, 2011 | 02:51 PM
haydukelives's Avatar
ticking r22
Hello all
I have a 1982 pickup that makes a ticking, or clacking noise that goes faster in sync with the rpms, after the truck warms up i dont notice it, it isnt quite as loud, does this require attention?
Old Sep 22, 2011 | 03:05 PM
abbazabba's Avatar
this is probaby your valves its normal but they should be adjusted every time you change your oil
Old Sep 23, 2011 | 06:29 AM
83's Avatar
83
Sorry to nitpick, but I just can't understand the r22 thing...I see it on craigslist all the time. I mean, if you've opened the hood of your truck, it's clearly 22r. My apologies if you're dyslexic...
Could very well be that you need a valve adjustment, but I'd check the timing chain guides too, just to be sure. You don't want that thing breaking or eating a hole through the time cover...bye bye engine if that happens.
Welcome to Yotatech!
Old Sep 23, 2011 | 06:50 AM
pruney81's Avatar
The valves could be a little loose. Nothing wrong that though, it's better to have them a little loose than too tight.
Just pop off the valve cover and check the valve's and timing chain and guides. I don't get the r22 thing either, weird.
Old Sep 23, 2011 | 02:56 PM
WHEELER8688's Avatar
alot of people posting on here about the valves ticking
Old Sep 23, 2011 | 04:03 PM
Smile R22
Well I call it an r22 'cause I don't use motor oil in it, I charge the motor with FREON every 3,000 miles.
Davebarbier
Nov 3, 2015 03:28 PM
kawazx636
Sep 29, 2015 08:22 AM
Tacoma1313
Sep 15, 2015 07:51 AM
ErikZ1220
Sep 10, 2015 04:53 AM
gtwnbill
Engine Swaps
Aug 18, 2015 04:07 AM
