sun roof drains
sun roof drains
Would anybody happen to know where the end front passenger side drain tube exits. I know it comes down through the a pillar just cannot figure out where the end of the tube is.
Cheers
Cheers
FIll water into it and look for a puddle? :p
Figured it out. Actually runs down the A pillar and ends up running right by the ECU into the channel that runs under the door. That channel was filling up and not draining causing my floor board on the passenger side to get soaked. There are approx 3 or more small opening in that channel that drain the water and they were clogged. Now just need to find a good way to clean that channel out.
The following users liked this post:
ev13wt (11-13-2018)
ev13wt (11-13-2018)
my description above may have been lacking somewhat, but it drains into the rocker panel under the door, then there are 4 little slots underneath where the water is supposed to drain out. the slots were plugged allowing the rocker panel to fill up with water and draining back into the cab.
Thanks for the help guys
Thanks for the help guys��������
ev13wt (11-14-2018)
Not seeing this one wallytoo. Would not happen to have a pic of that one would you? Just want to make sure I get them all cleaned out, because the only ones I am seeing are the ones in the pinch weld under the rocker panel.
