Blue/Red temperature lever
Old Dec 4, 2018 | 09:45 PM
Dtay1981's Avatar
I have a 88 pickup 22RE 4WD. The temperature control lever (slides from blue to red) will not stay all the way on red. I can push it over and hold it, and the air gets a lot warmer, but once I stop holding it, it goes back to about midway and the air cools down some. Will this be something to do with the cables? I have done searches, and can’t find what I’m looking for. Thanks in advance for the information.
Old Dec 4, 2018 | 10:40 PM
mholme's Avatar
That lever should connect directly to the heater control valve on the firewall. Have you looked under the hood to see if the valve is fully open when you move the lever to full heat?
Old Dec 5, 2018 | 12:18 AM
ev13wt's Avatar
5 Year Member
The lever controls a gate under the dash and the heater valve in the engine compartment next to the brake booster. It is two different mechanical things. If the vavle cable breaks, you can still have hot or cold air by moving the gate.
Does the under the hood valve move freely? Unhook the cable there and test in inside.
Old Dec 5, 2018 | 02:13 AM
Dtay1981's Avatar
Thanks for the information. I’ll check under the hood this afternoon. I was hoping it’s something simple, I just didn’t know what to look for. This helps a bunch.
Old Dec 6, 2018 | 12:43 PM
Dtay1981's Avatar
Okay, so I looked at the valve under the hood. I can move the cable in and out with pliers, and can open and close the valve with my hand. But once I re-connect the cable and move the control on the dash, it doesn’t really move the valve. Maybe a very little. Seems like the cable may be in a bind somewhere. Guess I’ll have to pull the dash and see what’s going on?
Old Dec 9, 2018 | 01:51 PM
ev13wt's Avatar
5 Year Member
The valve is old and could be sticking. If it isn't that and it often is, then have fun pulling the dash.
Old Dec 22, 2018 | 11:27 AM
mholme's Avatar
An interesting thing happened to me the other day. I tried to change my flap setting to defrost and my heat level to full cool. Neither lever would move much and the knobs kind of went sideways when I tried. I popped the front panel off and a white clip fell out. I went ahead and pulled the control panel loose and both of the levers were loose at the pivot mount. Turned out that clip holds both of them in place allowing them to pivot. It’s a two piece snap together clip. 1 goes over top of the lever mount and 1 goes on the bottom and clips in to place. I opted to just drop in a screw and washer from the top and tightened it down with a nut over the original bottom clip. Worth checking out if you haven’t figured this out yet. My truck has AC so your setup may vary a bit if you do not.
I’ll try to edit with a picture when I get back to the garage.
Yota Yeti
Jun 29, 2010 05:16 PM
toyospearo
Feb 14, 2009 12:50 PM
TC4RNR
21
Jun 5, 2008 10:06 AM
