Whats the proper term?
Old Nov 15, 2018 | 06:57 AM
bayoulee's Avatar
Can someone tell me what temperature control set up Is called? A couple of the switches don’t work, and plate is broken and worn so I can’t tell exactly what’s what. Also, any good sources for new. Haven’t had any luck finding used, and when I have found new = expensive. Thx
Old Nov 15, 2018 | 07:07 AM
L5wolvesf's Avatar
Since your location is not posted in your profile its hard to determine if there are part sources near you.
Try searching "Heater/A/C control" here - http://car-part.com/
Old Nov 15, 2018 | 07:28 AM
scope103's Avatar
You also don't give your make/model/year/engine. Sometimes (lots of times) it matters.
I always start with one of several dealer sites. This is my favorite: https://parts.lakelandtoyota.com/sho...rimLevel=18380 It's a brick-and-mortar dealer in Florida, but I've had good service from them to California.
You can even use that site to get the part number, then put the part number into your favorite search engine. https://www.ebay.com/itm/5591035090-...-/183259921060 (But don't be too surprised that many secondary sources are MORE expensive than this dealer!)
Old Nov 15, 2018 | 08:06 AM
ev13wt's Avatar
5 Year Member
I bought new from Toyota. It the only thing that looks good inside :p
Use toyodiy DOT com to find your part number!
Old Nov 15, 2018 | 06:01 PM
Discombobulated's Avatar
From his other posts I think it’s an 87......man how does that panel get so beat up??
Old Nov 16, 2018 | 06:04 AM
bayoulee's Avatar
yes, sorry itsan 87. Not sure how it got in that shape, it’s been that way since I got it. The face plate is real thin and brittle. The fresh/recirculated switch and fan are all that works. Heat had to be turned on under the hood with a pair of pliers, and it is very stiff
Old Nov 16, 2018 | 06:38 AM
dropzone's Avatar
Fossilized
Looks like it was a stolen and trashed by crackheads
Old Nov 16, 2018 | 06:43 AM
scope103's Avatar
Originally Posted by bayoulee
... Heat had to be turned on under the hood with a pair of pliers, and it is very stiff
That's probably not in the CONTROL ASSY, HEATER OR BOOST VENTILATOR . If the valve under the hood is stiff (and the actuator wire is off), you may just need to replace the Valve Assembly, Heater Water https://parts.lakelandtoyota.com/showAssembly.aspx?ukey_assembly=482350&ukey_make=1 060&ukey_model=15426&modelYear=1987&ukey_category= 21649&ukey_driveLine=6708&ukey_trimLevel=18292 , and re-attach the actuator wire.
The Control Assemby is just a combination of levers that pull actuator wires, plus the motor switch (which you say works). I would consider carefully removing your current control and figure out what, if anything, is wrong with it. You already know that the Valve Assembly is probably bad, so you don't want to replace the wrong part if you can help it.
PS Have you tried something like Armor-All on all that plastic?
Old Nov 16, 2018 | 10:07 AM
Good post scope, OP, you’re gonna have to dig into it and get it sorted, but once you get stuff apart it isn’t that complicated and it will be worth your time. Way better than the defroster units your looking at in your other posts. You can also get the heater control faceplate off of eBay they are not hard to find.
good luck keep us posted on your progress
Old Nov 16, 2018 | 12:20 PM
old87yota's Avatar
I agree with the above.
Before buying parts, lets investigate where, exactly, the problems you are having lies. You may have bad or stuck levers and cables or broken parts on the other ends of those rods / cables.
It does sound like your heater control valve is corroded to the point that it is very hard to turn (Vise Grips) and should be replaced.
The face plate is separate from the heater lever assembly (Control Assembly, Heater or Boost Ventilator). The face plates get damaged primarily by the sun, and get brittle over time with temperature changes, UV damage, and people poking at the face plate.
It looks like your interior was .... not really in the interior. The mud and water droplet rings in the mud suggest that the interior was fully exposed to the elements at some point.
The face plates I have seen on eBay are more expensive than what my local dealer charges (and they charge full MSRP).
If you need some new knobs (it looks like you are missing two), they are pretty inexpensive from Toyota. Knob part number: 55905-89110
ByThaBay
17
Sep 17, 2004 09:01 PM
crawler#976
Apr 15, 2004 01:18 PM
Woodbert
Dec 29, 2003 01:07 AM
sschaefer3
17
Jul 7, 2003 08:07 PM
