Low idle on hot startup 92 22RE
After truck is hot and I restart it, RPMs stay right at 500 and will not move until I feather the gas and idle will go to 1000, then drop perfectly to 750 and stay there. I cleaned the IAC valve from what I could get to from removing the gray access cover, which was not really that dirty, and that didn't fix the problem. Coolant temp sensor (ECT) is within specs. Should I throw a new IAC valve on or is there anything else I should check first?
Thanks.
Thanks.
The following users liked this post:
Paul22RE (11-17-2018)
So I shouldn't be able to blow through that larger air hose that comes from valve cover to IACV after engine is hot?
TPS was just adjusted to within specs while I had TB off and fully open/closed readings were all ok. I will see if I can blow through air hose leading to IACV after warmup.
I dunno how you plumbed this but my idle valve lines do not go to the valve cover. It should run from one side of the throttle plate to essentially the other.
I'm gonna go try and dig up photos, cause I'm not going out in the snow unless the house is on fire.
which hose shouldn't I be able to blow through after warmup?
I replaced the IACV and the problem persists. Any ideas what to try next?
Sure the vaccum lines under the pot and egr system are attached, attached correctly? Get some OEM vac lines and replace everything.
Recheck TPS. If not tightened down TPS screws before
Measure the 500rpm, make sure it's not just the gauge. (amazon laser rpm meter thingy is a couple of bucks)
Keep blipping the throttle
Paul22RE (01-07-2019)
I had a random high idle, and a new IACV fixed that.
My 92 does the same thing randomly on hot start. My throttle body is clean as it gets. I have come to the conclusion that it's probably wobble in the throttle plate. LCE sells a throttle body rebuild kit, but I don't need the gasket and the fancy idle screw. Just need the bushings. Have not pursued just buying the bushings, so not sure where to get them.
https://www.lceperformance.com/22RE-...-p/1061048.htm
Pull the air hose off the front of the throttle body and try wiggling the throttle plate, try pushing it up down left right and in and out, it should be very rigid if you notice any change in the gap between throttle body housing and plate it indicates it has worn out. No one makes a service kit for this failure mode. The LCE seals might help some but the root issue is the plate not returning to a consistent position.
I''ve just put some very light oil on a paper towl and "cleaned" the tb plate and housing where it sits at idle, leaving a thin film of oil. Also put some on the return spring, hoping it will flow into the shaft. I was chasing a surging issue, which turned out to be a vacuum line that was unhooked. But the TPS shaft is now buttery smooth, where it was a bit dry and would lightly catch on itself at times.
With engine off, check the condition of the throttle cable by having someone press the gas in the cab. No binding or sticking? No loose strands of wire?
Paul22RE (01-08-2019)
Yeah, I replaced that o-ring and blew air in all coolant passages and all new coolant hoses. I think I will try that LCE TB rebuild kit, wonder why they include a fancy idle screw instead of a new shaft?
