1986 22re (W56) Random Misfire At Idle and 2000-3000 RPM Range
Old Nov 18, 2018 | 05:45 PM
outdoorjunky's Avatar
5 Year Member
Guys, I've spent the last 6 weeks trying to track down the source of a random misfire at both idle and also (only) in the 2000-3000 rpm band on my fresh rebuild 1986 22re in my 86 4runner DLX. It is definitely ignition related because I'm seeing dropped spark on all 4 cylinders. to keep this simple I will just list all the stuff that tested with high resistance and I replaced along the way as well as some other systems that were replaced.
New parts:
-Distributor cap
-Rotor
-Distributor its self
-coil
-igniter
-igniter wiring between ECU and igniter (found shorts happening between the 3 wires from getting cooked over the years)
-tested plug wires and coil wire, all tested good
-replaced fuel pump
-replaced fuel pressure regulator
-injectors rebuilt
-all vacuum hoses replaced
-intake tube rubber flex tubes replaced also checked for leaks on the PVC intake tube
-replaced and calibrated the TPS with new OEM TPS, old one had mechanical lag
-tested the circuit opening relay
-tested to make sure the AFM opens the circuit opening replay and turns on the fuel pump and it does
-I also ran the truck with the fuel pump jumped (B+ and Fp) just to make sure it wasn't the AFM connector getting intermittent connection and causing the fuel pump to drop out, no change in behavior
-I checked valve clearances several times and they are good
-I also ran compression tests on all 4 cylinders and they are well within spec and only deviate 5psi between all 4 cylinders.
-Tested the EGR valve and the engine stalls when vacuum is applied with my mighty vac tool (according to FSM this is a positive good test)
-also checked that there was no vacuum at idle on the vacuum modulator and tested the Thermal vacuum switch on the front of the lower intake.
-Vacuum at the intake plenum is 21" of vacuum
-Sanded all engine grounds to bare metal and reattached ... tested negative sides for voltage drops all was good.
-tested TPS and AFM pins from ECU side
-Tested Various ECU pins to ground as well as resistance tests
-pretty much every wire from the ECU side checked out ok, the readings were the same for the TPS and the AFM as they were from the pins on the units themselves... I didn't really see any variations in resistance on anything until I noticed the igniter wires were shorting when they got really warmed up ... if I giggled them while doing a continuity test I was dropping tone and the resistance was going to 0.000 that said the voltages to the igniter from the ECU side were within spec listed in the FSM 0.7 volts to 1 volt. I didn't manipulate the wires at all when I tested the voltages though as I hadn't gotten to testing the resistance between the ECU pin side and the connector end of the igniter wiring.
several times in this process the truck ran great as if it were fixed for 1/2 a test run or an entire test run only to start missing randomly the next time it was started or half way through the test. I can recreated the misfire from the engine compartment by manipulating the throttle and it always starts around 1800-2000rpm range and ends at about 3000 rpm. no missing bellow or above those ranges except at idle. it will rev steady then suddenly pop pop....pop...pop pop. most of the time when I've replaced parts I pulled the battery leads which in turn resets the ECU so I'm assuming at this point (since I've gone through the entire list of troubleshooting ignition issues listed in the FSM except for the ECU) that its the ECU. I notice that when I put a timing light on the crank pulley and get the misfire to happen the timing mark advances really far over to the left sometimes taking the timing mark out of sight ... I've read that the ECU's can be faulty and cause the timing to advance too far which will cause a random misfire like I'm having but I'm not really sure what too far looks like. I read a tech bulletin that suggested retarding the timing to 3 degrees instead of 5 (base timing) so I also tried that but it hasn't corrected the misfire. Retarding the timing was one possible solution for the advance issue but the second was a replacement ECU. I'm at the point where I'm going to start looking for a second ECU to test this with but I wanted to ask here just in case there is something else obvious that I'm not seeing? I'm grasping at straws at this point. Any suggestions?
Thanks in advance!
Old Nov 18, 2018 | 06:22 PM
wallytoo's Avatar
the "pop, pop, pop" could be lean misfire. what is your fuel pressure?
don't get another ecu, you'll be disappointed.
Old Nov 18, 2018 | 06:53 PM
5 Year Member
I've got a gauge on the cold start banjo and it's reading within spec. Like I mentioned the fuel system has been gone through as well ... new pump , regulator, injectors cleaned and recapped and new micro screens... also ran a backup set of injectors to be sure and same issue. the injectors fire away with no mis when the engine misses... I listened to all of them with a stethoscope and they never miss. fuel pressure is around 30psi max 40psi and it's a liquid filled gauge using one of LCE's modified banjo bolts. when it's running at idle its around 30 psi and jumps up as throttle applied if the ignition is at the on position and I jump the Fp and B+ ports the pump puts out 40psi. Also watched to see if fuel pressure drops on my gauge when the misfire happens but it's steady. Also I verified the misfire is coming from ignition i.e.: random misses on the plug wires. everything there has been replaced .. distributor, coil, tested a new set of NGK wires for the hell of it, distributor cap and rotor... even went back to my old cap and rotor just to be sure it wasn't a bad new cap and same thing ... second igniter and I rewired the igniter wires to the ECU.
Old Nov 18, 2018 | 08:25 PM
5 Year Member
Another thing to note is the previous owner swamped the truck and hydro locked the engine with water then he said he rebuilt the engine but after I had major issues and started tearing into it, it became obvious he just pulled a junkyard engine and put it in. So, the ECU could potentially have gotten wet, actually sounds like it definitely did get wet so that's another reason I'm wondering if these symptoms could be ECU related.
Old Nov 18, 2018 | 11:18 PM
ev13wt's Avatar
5 Year Member
Spark plug gap is correct?
Is the number 3 ground wire attached to the head?
Does it drop idle when you jump the "test connector"?
Old Nov 19, 2018 | 02:44 AM
5 Year Member
yes plugs are gapped by me .31 per FSM I also tried .32 at one point but like I said it’s missing before the plug stage I can see that with the induction light test on the wires individually.
Grounds have all be sanded and reattached including the igniter/coil housing and my number 3 ground connects to the firewall and directly to the head via the rear engine hanger bolt. Other grounds are: harness to middle of intake plenum (injector ground),battery to block via AC bracket bolt, and alternator harness ground to PS bracket.
Old Nov 19, 2018 | 03:17 AM
Co_94_PU's Avatar
Verify the female side of the involved electrical plugs are tight. By this I mean tight enough they are a little difficult to put together, this will shave a bit of the prong when they get put together to the bright clean conductor. Just don't deform or break anything.
​​​​​Then pop the cover off the ECU. Take a bright diffused light high resolution photo. Will be looking for water marks (typically white crusty bits), dry solder joints (silver crystalline, not smooth mirror), loose connections (micro gaps), and discolored components.
Old Nov 19, 2018 | 03:44 AM
ev13wt's Avatar
5 Year Member
I'm gonna do that on the weekend just to check it out. Thanks. Great idea. Gonna see if there are any caps on there I could change out. 32yo caps!!
OP, did you measure you have idle on the TPS? (Does it drop RPM when you connect the test jumper, as if you where checking engine timing?
Old Nov 19, 2018 | 06:34 AM
5 Year Member
10-4 will do.
Old Nov 19, 2018 | 06:36 AM
5 Year Member
I'm gonna do that on the weekend just to check it out. Thanks. Great idea. Gonna see if there are any caps on there I could change out. 32ya caps!!
yes base timing is able to be set, the idle drops and the timing mark moves from around 10-12 degrees to 5 degrees when the diagnostic connector is jumpered.
Old Nov 19, 2018 | 07:46 AM
ev13wt's Avatar
5 Year Member
I also have the issue, but here it is more like cylinder just not firing. No "pop" at all to speak of.
On mine it will just "miss" a spark, rpm drop ever so slightly, and it keeps going. It is MUCH better now with the number 3 GND connected, but you already checked that.
Old Nov 19, 2018 | 08:04 AM
5 Year Member
the pop I’m getting is really much more of a bump bump bumpbumpbump than an explosion type backfire its a dead misfire I just was trying to explain the rhythm that it has at 2000-3000rpm. I’ve found out there are many many things in these systems that can cause a misfire haha 😂
Old Nov 19, 2018 | 09:12 AM
ev13wt's Avatar
5 Year Member
I'm uploading my misfire right now.
My plan is indeed the 3°, 2° remedy, after checking the ecu.
Does yours sound like this?
https://www.youtube.com/watch?v=MuAp...ature=youtu.be
Old Nov 19, 2018 | 09:51 AM
5 Year Member
https://youtu.be/MuAp7TTQ3Fw
i cant hear anything but valve train noise in the video but that rpm range is when it happens for me too
Old Nov 19, 2018 | 12:19 PM
5 Year Member
I
does your truck start running warmer than normal when you are driving in that rpm range? When I’m at HWY speeds or crawling up a hill in 2nd gear at that rpm range my temp gauge starts rising... if I change gears or the engine is in a situation where it’s not under Load and missing it cools off fast. I never overheat per say but it rises above the center line by about 3 needle thicknesses which isn’t normal. I tried other senders too and got the same result. It really just shows higher temps if I’m riding the engine in that rpm band where the mis happens so seems like the ECU is leaning the mixture too much or something causing higher cylinder temps. My entire colon system is new and I’m using a dual stage OEM thermostat as well... has a single stage with same behavior.
Old Nov 19, 2018 | 05:12 PM
5 Year Member
I popped open the ECU and there is definitely evidence of moisture getting in, the inside wall of the case has a bunch of corrosion spots and an entire row of resistors and silicon chips have corrosion at their solder points and some may be leaking. And guess what? There is corrosion/discoloration surrounding the solder point for the IGF pin on the circuit board which is the igniter signal pin.
here are pictures
Old Nov 19, 2018 | 05:21 PM
5 Year Member
A couple better closeups of the chips and some of the resistors.
Old Dec 9, 2018 | 10:28 PM
5 Year Member
Ok so I'm back. I procured a spare ECU for 50$ it wasn't the problem (of course) but still I wanted a spare ECU and 50$ was a price I couldn't turn down. that said I have new info on my problem. I started going through testing the main replay, starter relay, injector solenoid all of that tests good. then I started up the truck this evening and just started shaking the engine wiring harness portion that goes from the firewall to between the intake plenum and the truck died on me. I reproduced this 4 times in a row by touching one area of the harness. Looks like the previous owner was in there at some point because it's sealed up with electrical tape. My bet is ether there is something incredibly jenky going on in the harness with some sensor wiring or ecu grounds or I have the dreaded fuel injector split of death issue going on. I need the truck for the next few days so I can't tear into it now but after Tuesday evening I can pull this apart and correct any issues I find. I'm fairly certain it is the injectors because when the engine died I could hear the injectors clicking and trying to fire if I continued to manipulate the harness. I guess I'm glad this never happened to the point of stalling while I was driving it.
Old Dec 10, 2018 | 02:59 AM
wallytoo's Avatar
if you need to repair the injector wiring, etc., it's a great time to replace the injector connectors with some updated ones that have a better clip retention design, which are easier to disconnect while the entire plenum is still installed (virtually impossible with the oem connectors).
Old Dec 10, 2018 | 12:25 PM
5 Year Member
yeah that’s the plan for sure to replace them with the wire spring clip type instead of the square ones that need a screwdriver to pry the clip off. Definitely just gonna go through the harness with a fine tooth comb and address anything I see because I’d rather not buy another plenum gasket after this or have to pull the harness out again.
