Rear Drum Clearance/Cooling
Old Dec 27, 2018 | 08:58 PM
stanz's Avatar
This coming spring I will be embarking on a Tacoma width SAS swap paired with a Taco rear axle. My question is, I test fitted the factory 15 in rim on the Tacoma axle and there is about 1/2 an inch of clearance between the drum and the rim... the drum pretty much fills up the entire rim... should I be worried about this impacting cooling/brake fade? In other words, do I need to upgrade to a 16 in or 17 in rim?
My driving style doesn't typically involve frequent hard braking, so I'm thinking I should be ok. Thought I'd put this out there to see what others have to say.
Thanks in advance!
Old Dec 28, 2018 | 05:56 AM
se7enine's Avatar
My Tacoma has 15's and I don't have a problem. It was a stock wheel size. Just make sure the LSPV is adjusted properly.
SharpStick
Aug 29, 2015 12:59 PM
dbcx
12
Mar 20, 2008 01:47 PM
vtruong1
10
Nov 6, 2004 05:11 PM
dirk diggler
Aug 22, 2004 05:03 PM
LCruner
Jun 14, 2004 05:53 PM
