rear drum brake adjustments
Old Jun 14, 2004 | 10:24 AM
LCruner's Avatar
I just changed my rear brake shoes. My one question is after i bleed the brakes I had very little peddle, it went to the floor. I beleive thats because the wheel cylinders and shoes were not adjust all the way out. I worked the parking brake several times because I thought it would extend that adjuster screw, it worked but is that the correct way or is there another way. thanks
Old Jun 14, 2004 | 10:42 AM
keisur's Avatar
if you didn't disconnect the line during the change you didn't need to bleed them. you may have to bleed them again, there's air in the line.
Old Jun 14, 2004 | 11:13 AM
Fahrenheit 451's Avatar
How far out did you adjust the rear brakes with adjusters after the install? They should be run out until the drum starts to drag, then backed off until they stop dragging.
I believe the adjusters will only advance the pads when the vehicles is in reverse and the brakes applied and even then only if the adjusters are working well. Since most adjusters wind up full of junk and/or rusted they usually don't work well or much at all unless you really cleaned them up when you did the pads.
Old Jun 14, 2004 | 11:23 AM
Gadget's Avatar
Manually adjust the rear brakes before you kill yourself.
Gadget
Old Jun 14, 2004 | 01:58 PM
mike_d's Avatar
the adjuster works when using the brakes in reverse. i'd manually adjust them first, but to fine tune it, just apply the brakes a couple of times while going backwards.
Old Jun 14, 2004 | 04:25 PM
Tokez420's Avatar
drums suck
Old Jun 14, 2004 | 05:53 PM
keisur's Avatar
I always adjust mine with the parking brake and then I check them to get it close, then I do the reverse thing.
Jun 1, 2021 01:51 PM
87turboPA
Jul 12, 2015 07:49 AM
garagespace
Jul 9, 2015 08:37 AM
87turboPA
Jul 9, 2015 05:58 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
