FOUND.Complete rear drum to drum w/e-lockr
Old Mar 17, 2008 | 02:06 PM
dbcx's Avatar
UPDATE: NOT FOUND.Complete rear drum to drum w/e-lockr
I found a complete rear end drum to drum with an E-locker. They are going to take it out for me and if they dont have to much trouble they are going to pull the wiring also. It is out of a 99 mine is a 97 and it is the same gear so all i should have to do is clean it up a swap them out. I cant wait to gp get it.
Old Mar 17, 2008 | 02:15 PM
Fo-runna's Avatar
Sweet! How much $$?
Old Mar 17, 2008 | 02:28 PM
pattycakes77's Avatar
all i can think of is...
http://youtube.com/watch?v=76bLITHVpL8
good find!
Old Mar 17, 2008 | 02:32 PM
dbcx's Avatar
$500, i go pick it up. Its cloe to my house also. It is going to delay my lift plans a few months or so i think.
It should swap right out correct?
Old Mar 17, 2008 | 02:34 PM
Djlarroc's Avatar
Cheeyat, I'll take an e-locker over a lift ANYDAY!
Old Mar 17, 2008 | 02:37 PM
cackalak han's Avatar
Should be a direct swap. Get the "RR DIFF LOCK" button, too.
Old Mar 17, 2008 | 02:42 PM
dbcx's Avatar
[QUOTE=cackalak han;50781272]Should be a direct swap. Get the "RR DIFF LOCK" button, too.[/QUOTE
Im gonna try and get it all. He said i could have it but didnt want to tie up a tech to long trying to get it out. I told him to get it to the inside cause i wont be able to get under it and id pull it the rest of the way. I hope i can get the whole harness, thats the only thing im unsure of so far
Old Mar 17, 2008 | 02:45 PM
bigt's Avatar
get EVERYTHING you can tis worth it to go there yourself after they pull the axle and get any harness you may need... your luck man and good luck
Old Mar 17, 2008 | 06:41 PM
k_southman's Avatar
Are you sure it will be the same ratio as your front? If you have a v6 auto your ratio is likly 4.10, and if the locker is from a v6 it is likly a 4.30. You may want to have a look at your door sticker and make sure it is the same.
Old Mar 17, 2008 | 07:16 PM
Elton's Avatar
e-lockers are sweet you prob got it alot cheaper than mine well mine did come with a new truck lol
Old Mar 18, 2008 | 02:57 PM
dbcx's Avatar
Yes ,door codes the same, i checked.
Should i try and get the rear coils? Wont they sit just a hair higher than my 97 stock coils?
Old Mar 18, 2008 | 04:02 PM
Whitey13's Avatar
good find!
ninja edit!
Old Mar 20, 2008 | 01:47 PM
dbcx's Avatar
Sooo there I was, standing in the junkyard as the tractor was bringing my new E-locker rear end. Asit got closer i noticed some stuff missing,like all the locker part. It was the same damn rear end as i got. So i guess that was to good to be true. The guy said it was inventoried wrong....
okamikai
Apr 30, 2018 10:19 PM
SMOD
Jul 27, 2015 01:45 PM
Athansinis
Jul 27, 2015 08:38 AM
CanRunner
Jul 20, 2015 01:29 PM
icentropy
Jul 14, 2015 10:23 AM
