Cluster swap question
Old Jan 8, 2019 | 09:11 AM
Slayer99's Avatar
I have a 92 pickup 5 speed manual 2.4 I picked up an SR5 cluster from a 93 4runner V6 3.0 automatic transmission 4WD my question is should I remove the bulbs that do not pertain to my vehicle or will it cause issues with the cluster? Thanks
Old Jan 8, 2019 | 10:02 AM
se7enine's Avatar
I do know on mine I had some bulbs missing so I added all just to have spares on the cluster and a gauge stopped working but it may have been coincidence. Think it was the voltage. Then I removed all the unused bulbs and it started working again. From the back view it looks like some bulbs complete a circuit. I would start by removing the bulbs not needed and see if it has any effect. If it does follow the path from what isn't working and see if it's tied to a missing bulb.
Old Jan 8, 2019 | 11:31 AM
Paul22RE's Avatar
5 Year Member
Are you also swapping the black surround bezel? It will not be an exact fit but can work with a little cutting of tabs and hole mounts.
Old Jan 8, 2019 | 04:24 PM
Discombobulated's Avatar
Swapped my cluster in my 91dlx pickup and had no issues leaving everything as far as bulbs alone.
Old Jan 8, 2019 | 07:00 PM
Co_94_PU's Avatar
The cluster in my 94/2wd 5 spd is the cluster from a 4wd automatic, I didn't remove any bulbs. In fact I believe I swapped all the blub cages from the original into the auto to have on hand as spares.
The only "wild card" is the dash harness, you can't have any sources to ground the multi guage/cluster doesn't expect. You would have toxo sule the pin out (wiring diagram) of source and donor (like the big sticky thread recommend)..
Old Jan 9, 2019 | 05:19 AM
Slayer99's Avatar
Thanks guys, swap is done I just left all the bulbs in and everything is working except the oil pressure gauge which I have to swap out the old sensor for the gauge version, it’s unplugged until then. Paul22RE no just the gauge cluster.
Old Jan 9, 2019 | 06:16 AM
scope103's Avatar
I hope you remembered to disconnect the oil pressure switch BEFORE you plugged in the new combination meter.
Old Jan 9, 2019 | 06:45 AM
Slayer99's Avatar
I sure did, Thanks
Old Jan 9, 2019 | 03:22 PM
Sweet, I found this upgrade to be the more rewarding one of the sr5 options
Old Jan 14, 2019 | 03:04 PM
Slayer99's Avatar
Spoke to soon, I picked up a new oil sender, it said for use with gauge, but the gauge is reading extremely low, when I’m on the interstate the highest it goes is a tad above 1/4 on the gauge at idle it’s at 0. I’ve been reading there are two different types perhaps I got the wrong one? Here is the one I got. https://www.oreillyauto.com/detail/b...070=With+Gauge
Old Jan 15, 2019 | 05:50 AM
se7enine's Avatar
I've got over a 1/4 gauge reading deviation from idle to drive as well although mine is max a little over half way and around 1/4 at idle. My last 22RE was max under 1/2 and almost 0 at idle. I think it will always vary depending on condition of oil gauge and engine. Maybe a genuine OEM gauge will read better I don't know.
Old Jan 15, 2019 | 08:47 AM
I would just get a OEM from a yard, yota Jim’s here in Colorado ship, give them a call and check it out. Mine does read low though I will take some pics here in a few to compare to your readings. These gauges from what I can gather don’t tell me much besides I have pressure. As long as it’s moving that’s all I need as it’s still better than the idiot light
Old Jan 15, 2019 | 09:04 AM
Here is at idle from a warm start, but on a hot day it usually is a smidge lower after driving
Here is at 2800 no load, but honestly I can’t remember that it gets much higher during higher RPM’s, I’ll check it out on my way home.
Old Jan 15, 2019 | 09:59 AM
scope103's Avatar
Originally Posted by Slayer99
... the gauge is reading extremely low, when I’m on the interstate the highest it goes is a tad above 1/4 on the gauge at idle it’s at 0. ...
That's about what mine reads with warm oil. Reads a little higher (at idle) when the oil is cold.
You know, of course, that the meter has no calibrations so you can only use it in a relative sense anyway.
Old Jan 15, 2019 | 11:15 AM
Slayer99's Avatar
I appreciate the info, here where mine is at
Old Jan 15, 2019 | 03:26 PM
Co_94_PU's Avatar
​​​​​​put a numeric guage on it if you really want hard numbers to compare..
Note ​​​the position when the engine isn't running this is the rest position, it will climb above this when the engine is ran. That first section of the scaled guage is fine at and near idle. The third and forth sections are bad places and indicate the filter bypass is active..
Bottom line, if it moves in to section one and stays out of the last two it is good. If you want actual psi you need a numeric guage.
Old Jan 16, 2019 | 03:06 AM
Slayer99's Avatar
Guess I was just expecting it to be higher on the gauge, comparing to my cobra which it above half on idle and 3/4 while driving.
Old Jan 16, 2019 | 03:32 AM
I mean you could try a different sending unit but might be in the same boat, you know the truck runs great so as long as the gauge is in the spots your used to that tells you all is well. I have never been concerned about where it’s at as long as it’s doing something
I was just excited to have more moving stuff in my cluster and a tach!!!
Old Jan 16, 2019 | 03:46 AM
Slayer99's Avatar
I agree, I might try a different sender as I found one that specifies Yazaki so might try that.
Old Jan 17, 2019 | 09:00 AM
Slayer99's Avatar
So I picked up the other oil sender that specifies Yazaki as that is what my cluster says on the back it appears to have worked.
