Checking out W56
Old Dec 26, 2018 | 08:43 AM
roughridn_sob's Avatar
Checking out W56
Im going to check out a W56 trans today to replace my current one. What should I be looking at as far as shaft play and other things? also it doesn't have a shifter so how would I go about making sure it cycle through all the gears?
Old Dec 26, 2018 | 08:45 AM
se7enine's Avatar
I personally wound't buy a used trans unless I was able to drive test it first. If I planned to rebuild it then sure I'd take the chance.
Old Dec 26, 2018 | 10:11 AM
I do plan a rebuild on either my current or this one, mines missing 4th gear. I’m getting it cheap just wanna know what I should be checking for maybe to determine if this one is better than my current.
Old Dec 26, 2018 | 01:07 PM
millball's Avatar
'Bout all you can do is judge the fore and aft endplay in the input shaft bearing and its sideways slop. There should be very little.
It might be possible to change that bearing out without complete disassembly of the tranny. I'm not sure.
You could put your shifter on it and turn it by hand through the various gears, but that's not likely to tell much unless there is major internal damage.
Change out the seal inside the throw-out bearing collar, and the seal in the rear, between the tranny and transfer case for sure.
I've had good luck with used trannys, but I make sure to buy them from running trucks that were wrecked; Or from trucks that got engine swaps that precluded continued use of the original type tranny.
Funny that some guys think that their used trannys that have no warrantee are gold, and other times you can get one cheap. Depends on your karma, I guess.
Good luck with your new one!! Keep us informed!!
To wax nostalgic for a moment; I bought my first gen 4Runner for $500 with a bad tranny and my wife and I put a used tranny and transfer case in it that I bought for $200.
We stabbed that tranny into it on Christmas day 2013. It's still going strong.... So are we.
Old Dec 26, 2018 | 01:45 PM
Yeh Im picking this tranny up for $100
Old Dec 28, 2018 | 10:02 PM
papawhellie's Avatar
Parts are worth way more than that if you need them.
vsi1600
Feb 18, 2011 03:53 AM
PhilR
Jan 23, 2011 11:17 AM
91toy_yota
Aug 10, 2010 02:39 PM
bikerbob
Jan 8, 2009 02:13 PM
