Anyone have the LC Engineering Pro Flow Exhaust for 3VZ?
Old Dec 1, 2018 | 08:31 AM
joshc6464's Avatar
Hi Everyone,
Does anyone run with the 3VZE the LC Engineering Exhaust Kit? It is the magnaflow muffler (the salesman confirmed for me). I have the LC Engineering headers, and I would buy a 17" Cat to put on the truck with the exhaust. LC Engineering did not have a video of it running... I want to make sure there isn't much drone at 70 mph.
I like this setup because it's bolt-on, I can do it without taking it to a shop.
Thanks!
Old Dec 3, 2018 | 06:39 PM
joshc6464's Avatar
Bump, does anyone have a magnaflow or the LC Engineering Cat-Back and could potentially share a video of the drone at highway speeds?
Old Dec 6, 2018 | 10:23 PM
Spread5150's Avatar
5 Year Member
Interested in this as well !
Old Mar 30, 2024 | 05:51 PM
CheeseRind's Avatar
This post is old but did you ever get around to it? How does it sound?
Old Mar 30, 2024 | 06:04 PM
Spread5150's Avatar
5 Year Member
I ended up using a magnaflow cat and exhaust and had it welded up. Way less. Very happy with it. I have a thread on it if you check it out
Old Mar 30, 2024 | 06:49 PM
Steel_Beans's Avatar
Looks like you already got your new exhaust. Either way, check out the install I did on the LC kit,
Old Mar 31, 2024 | 04:11 AM
CheeseRind's Avatar
Originally Posted by Steel_Beans
https://www.youtube.com/watch?v=luJmeqUNhdY
Heh, I commented on your YouTube video, too.
You mentioned in your reply there that the cat you ordered from LCE but it’s a magnaflow 91005. That magnaflow PN however matches a straight through version without flanges. Not relevant to the swap I’m doing as it’s pre-OBD II but still odd, unless they’re buying the 91005 and welding the flanges on themselves.
Another thing is I noticed that’s a Street Max muffler in your video. LCE used to use magnaflow, so interesting to see they swapped to a different brand.
all in all, sounds good in your video. Thanks for uploading that, there isn’t a lot of content around 5th gen V6 trucks and exhaust.
Old Apr 4, 2024 | 04:45 PM
Glad you watch the video! I checked LC Enginnerring's site and the cat I used in the video has a different part number than the manufactuerer. #1043012.
Also I was not aware that the muffler they used was supposd to be a Magnaflow unit. It says on their website that its a "Street Max Muffler".
I suppose that Its a subsidiary of Magnaflow. Either way its a good system.
Chappell1992
Jul 17, 2013 09:30 AM
live4soccer7
Aug 6, 2009 06:19 PM
aikinsmike
Mar 10, 2008 06:43 AM
bad_brains
Mar 15, 2007 07:42 AM
MAXIMUS1968
Oct 28, 2006 01:43 AM
