Heater stopped blowing
Old Dec 30, 2018 | 06:17 AM
Johnsoline's Avatar
Found this line disconnected, it has something to do with it I'm sure. Stopped blowing suddenly, fuse is good, relay clicks.
Old Dec 30, 2018 | 12:39 PM
RAD4Runner's Avatar
What year Escalade?
Please see signature.
If 1986-1988... https://www.yotatech.com/forums/f199...l#post52104117
Old Dec 30, 2018 | 01:31 PM
dropzone's Avatar
Fossilized
wonder if it goes into that other thing?
might check blower motor resistor
Old Dec 30, 2018 | 06:30 PM
az4x4runner's Avatar
You can also apply battery voltage to that plug going directly to the blower motor and rule the motor itself out.
Could be the resistor, does the fan work on any of the 4 speeds (after you plug it back in)?
Old Dec 30, 2018 | 06:37 PM
Johnsoline's Avatar
Doesn't go into there, I've found what It's to. Note the female end is still stuck to it.
It's for the a/c button
Old Dec 30, 2018 | 06:38 PM
Johnsoline's Avatar
Battery voltage applied, motor does not work. I've taken apart the motor, and will post pictures of motor repair.
Old Dec 30, 2018 | 06:47 PM
Murphy's law, it's cold out!
Seems like you found the issue to be the motor. I assume you are getting the proper voltage if you turn the fan switch on and probe the blower motor harness? Just an additional check to make sure everything else is functioning as it should while the motor is out.
Old Dec 30, 2018 | 06:55 PM
Johnsoline's Avatar
Unfortunately, I no longer have probes. I will test with a lamp.
josh29356
Dec 30, 2018 06:57 PM
mikesta
Jan 3, 2011 12:36 PM
95Blue4Runner
Jan 19, 2010 05:19 PM
88wildrunner
Jan 10, 2009 07:37 AM
toyNG
7
Jul 19, 2008 02:08 PM
