Blinkers and OD
Old Nov 14, 2018 | 07:37 PM
yota tay's Avatar
Blinkers and OD
My 10 amp blinker fuse keeps on blowing and it's taking out overdrive when it does. Is there anything in common with these 2 circuits? Most of the time it pops the fuse as soon as acc are powered on. It pops without using anything at all. Any suggestions?
Old Nov 14, 2018 | 07:53 PM
RAD4Runner's Avatar
What year Escalade are we talking about here?
Please see signature.
Old Nov 15, 2018 | 03:32 AM
yota tay's Avatar
94 auto with overdrive.
Old Nov 15, 2018 | 03:55 AM
scope103's Avatar
By "Blinker" fuse, I assume you mean "Turn" fuse. http://web.archive.org/web/201204170.../2powersou.pdf I can't find any connection between that fuse and the Automatic Transmission in my EWD. The ACC position only powers the Radio and Cig fuse, so I am at a loss to explain how that could blow the Turn fuse.
"Most of the time" suggests you have an intermittent short somewhere; the wire is getting jiggled and shorting to ground. (but not all the time).
To save on buying fuses, a gadget like this might help you find the short. https://www.harborfreight.com/automo...ter-67724.html OR, you could just replace the fuse with a 12v test light; with the radio off (the clock won't pull enough current to light the bulb), when the light comes on you've got a short.
Old Nov 15, 2018 | 06:54 AM
yota tay's Avatar
Thanks for replying. I'm thinking the short is either in the steering stalk or the computer. Disconnecting all blinkers and even flasher relay doesn't stop the fuse from blowing. It blows in the position right before crank. I don't know why its preventing OD from kicking in. Every blue moon I'll put a fuse in on a cold start and my blinkers and OD come back only to short back out a little later. Once this happens, the fuse starts blowing once ignition is on.
Old Nov 20, 2018 | 06:49 PM
yota tay's Avatar
Ok update on my situation. After disconnecting the plug that goes from the steering column to the fuse board by the kick panel, the fuse stopped blowing. It seems its the combination switch which contains the blinker handle and gear handle, correct?
Old Nov 20, 2018 | 11:47 PM
ev13wt's Avatar
5 Year Member
MAkes sense to me! Figure out what wires need to touch, then do it, verify emergency blinker/flasher operation, put new switch in!
Old Nov 21, 2018 | 04:24 PM
yota tay's Avatar
I'm gonna just replace the switch. I'll update in a few weeks. Thanks.
Old Nov 22, 2018 | 05:32 AM
RAD4Runner's Avatar
I doubt if the switch causes your fuse to blow. Pls see signature. If it is SOOO bad it should be obvious and inspection should reveal it.
Ritzy4Runner
57
Sep 30, 2020 04:00 AM
nininick
Mar 23, 2012 11:24 PM
idanity
Nov 10, 2008 05:29 PM
Bob_98SR5
Jan 7, 2006 09:07 PM
JBHaywood
Feb 25, 2005 10:48 AM
