Need ideas on what might be the cause
Old Dec 17, 2018 | 05:38 AM
Robert Mason's Avatar
Problems.
Truck ran. Started having a metallic rattle from engine so I parked pulled plugs took belts off and tried to turn crank by hand I get almost 350 then dead stop.
Took intake plenium off noticed oil/water residue on the gasket above #5 intake.
Ran a bore scope trou plug holes no obstruction or moisture pulgs looked normal.
Runner is a manual transmission
Old Dec 17, 2018 | 05:42 AM
ev13wt's Avatar
5 Year Member
I am guessing it's the 3.0l. Else, no #5 plug.
Belts: did you take off the timing belt? (3.0 is not interference style, right?)
Take off valve covers and look if everything is moving like it should.
Old Dec 17, 2018 | 06:07 AM
Took acc belts off and valves look good. I have not removed timing belt yet
i have 2 ideas on the issue first being from when piston rings were replaced the bolts holding the connecting rod to crank shaft came loose. 2 I know my input shaft bearing is worn so is the clutch possibly a failure there getting cought up. Yes it's a 3.0. And thank God it's non interfere
Old Dec 31, 2018 | 04:26 PM
Pulled motor removed passenger side heads and found
Mechanical damage to piston cylinder wall looks goos
Mechanical damage to head
time to look at either grinding down the damage or replacing the head.. and swapping the piston out. Any tips on flushing out oil collent gallery to get what ever got cought in the cylinder out. Have not found anything that would have caused the damage yet
Old Dec 31, 2018 | 05:51 PM
superex87's Avatar
The object is most likely trapped in the catalytic converter now. The shape and size of the damage has me thinking it was a washer or sorts.
Old Dec 31, 2018 | 06:11 PM
Cat was cut before I recirece the truck. I am hoping you are correct but I don't think I will get that lucky because as soon as I pulled the block I tredt turning the crank but it was still binding
Old Jan 6, 2019 | 08:03 PM
Found a smashed nut seams to have been the issue. Any thoughts on if the head is repair-able or needs replaced
Kaleb
266
Jul 15, 2013 05:26 PM
Jad
Jun 18, 2009 03:55 PM
