ifs questions
Old Jan 31, 2008 | 08:15 PM
stupid_mud_gremlins's Avatar
ifs questions
ok...I have a really dumb question, are the springs on the IFS runners built into the absorbers, or is it like the old grain truck we had on the farm...torsion bars only?
Old Jan 31, 2008 | 08:16 PM
stormin94's Avatar
It has torsion bars, and separate shock absorbers.
Old Jan 31, 2008 | 08:22 PM
which provides the spring though?
Old Jan 31, 2008 | 08:24 PM
bry-an's Avatar
torsion bars are springs.... shocks are always just shocks... even on coilovers the shock is just a shock with a spring that happens to be on it
Old Jan 31, 2008 | 08:26 PM
So the next question is how much can I adjust them to raise the front end, if the front end is sagging? or should they be replaced?
Old Jan 31, 2008 | 08:37 PM
bry-an's Avatar
uhhh ok how to explain this,,,,...... ummm look under the truck and find the bars... they run from the upper A arms back and out to the frame rails kinda like this shape / \ they will look like about 1 inch around and black.... and the end is about right under the front seats. now lets focus on just one side(cause they are the same....) you will see a big nut sticking down.... (that sounds so wrong) I think its 24mm.... or 22mm.... all you do is tighten it.. check out www.4x4wire.com i think they have a writeup.... and then get an alignment. or pm elripster and he can send you a link to do your own.
Old Jan 31, 2008 | 08:47 PM
Sounds close enough for my liking. I'll let everyone know how it goes, and how nice the air springs go in the back end too. And I won't forget pictures....
Old Feb 1, 2008 | 08:49 PM
bry-an's Avatar
any pics yet???
Old Feb 1, 2008 | 09:15 PM
UKMyers's Avatar
Tweaking on the torsion bars will kill your ride quality!!
Old Feb 1, 2008 | 10:35 PM
shaeff's Avatar
unless you relax them.
Old Feb 1, 2008 | 10:41 PM
stormin94's Avatar
When used in moderation(IE, only 1 inch- 1.5 MAX) it shouldn't be that big of a deal. At least mine, with 1 inch isn't bad at all.
Old Feb 2, 2008 | 06:25 AM
my front suspension is darn near sitting on the bump stops... I'll end up replacing the shocks too, but what can I do about the springs if I want to maintain some of the ride quality. I should have some pics by the end of the weekend. I'll put them in a different thread though.
Old Feb 2, 2008 | 06:38 AM
elripster's Avatar
The front springs should be fine. It sounds like you need to raise the front a bit though so have some compression travel? Pics will definitely help us understand your situation better.
Frank
Old Feb 2, 2008 | 07:27 PM
mwilliam13's Avatar
So, I am trying to get something out of the torsion bars. I have turned that bolt head sticking down from where the torsion bar ends just under the front seats. I have turned it righty tighty probably 30 or more revolutions (tough to turn, so using a cheater bar on a ratchet wrench) and haven't seen any lifting. Is it possible that it is a reverse thread? or am I just being a pansy about it? I don't want to eff it up more than I can fix.
Old Feb 2, 2008 | 07:34 PM
bry-an's Avatar
hmm thats odd... your turning the big ass one right? look at the other side of it(top side) how much thread you got left? thats the best way to tell if you are doing something. maybe lift the front up on jacks and just turn it till it touches the ground..... not more than 1.5 inches though:S
Old Feb 2, 2008 | 07:45 PM
mwilliam13's Avatar
I measured from the top of the wheel rim to the top of where the wheel well and fender converge. It was 15.25". I then hung a box end wrench 1" higher than the top of the wheel well from the rafter of my garage. Truck hasn't moved height wise. I am going to get under the truck and see if there is any thread on the bolt or if it is stripped. That would suck. Will leave word of what I find.
Old Feb 2, 2008 | 07:49 PM
suspensions been kinda put on hold... fudged a head gasket on the way over to the shop today. Had one guy stop to ask if I needed help cause he saw the big cloud of smoke out in the field beside the road... he kinda figured it was me cause I was to only idiot sitting beside the road with my hazards on... Is this possibly a new name for the 3 vze, the 3. D'OH!
Last edited by stupid_mud_gremlins; Feb 2, 2008 at 07:50 PM. Reason: added comments
88sasturbotoy
Jan 30, 2026 01:57 PM
delmert
Sep 30, 2015 04:34 PM
Gevo
Jul 29, 2015 11:15 AM
coffey50
Jul 28, 2015 10:55 AM
scottyg486
Jul 19, 2015 05:34 PM
