3.0L oil pressue
Old Feb 5, 2008 | 01:20 PM
88yotadad's Avatar
3.0L oil pressue
How much oil pressure should a 3.0L have. I just got the oil gauge installed and at fast idle the gauge was reading 90lbs. That to me sounds to high. I did not have time to get the motor warmed-up so no idea if the pressure would drop once the engine warms-up.
Roger
Old Feb 5, 2008 | 01:52 PM
Tim_Snapple76's Avatar
i would think that figure would be a bit high, however, this is only a guess.
Old Feb 5, 2008 | 03:03 PM
86tuning's Avatar
High oil pressure, especially with cold oil, is perfectly normal. It basically means you can run a lighter oil. ie, 5w30 instead of 10w30. High oil pressure is a good thing.
If your oil pressure was low, that would be a problem, indicating damaged/worn bearings or oil pump. That would be a bad thing.
Old Feb 5, 2008 | 06:07 PM
thook's Avatar
Hey, Roger. You're back!
If the motor's cold....especially if it's cold where you live....that is normal. If it's higher than spec when warmed, that would be a concern.
Is the motor knocking or anything?
Oh, here's the specs....but, of course, this is for operating temps.
http://personal.utulsa.edu/~nathan-b...16oilpress.pdf
Old Feb 6, 2008 | 12:09 AM
88yotadad's Avatar
Yes it making noises but I'm thinking that it is the water pump. We have a small amount of fluid dripping down the block on the drivers side. I can not see from where so I'm assuming water pump.
Old Feb 6, 2008 | 09:24 AM
thook's Avatar
Well, it may be messy, but one way to locate the leak would be to spray aerosol foot powder around wherever a leak is possible. It's easy to rinse off, though.
Does the fan clutch have any play in it?
Old Feb 8, 2008 | 06:52 AM
88yotadad's Avatar
I thinking water pump or timing belt idler is my noise problem. I listened with a stethiscope(spelling). The next project is to fix this.
Roger
Old Feb 8, 2008 | 07:45 AM
yotaman90's Avatar
Does it sound kind of like a scraping sound?
defrag4
Jul 31, 2015 10:50 AM
JefferDean
Jul 31, 2015 10:39 AM
calderp
Jul 27, 2015 09:58 AM
nonstop
Jul 24, 2015 06:29 PM
Coreyr384
Jul 10, 2015 11:13 AM
