Warm idle miss
Old Feb 3, 2008 | 07:53 PM
Sonofmayhem's Avatar
Warm idle miss
Ok, 1986 Turbo 4runner 50k on the motor and 5k on the turbo. When I start it in the morning, it will run great till it is warm. Then i get a miss every other couple of seconds. I have new ngk wires and plugs, new cap, rotor, and coil. Still doing it. I cannot jump my timing because it dies when I unplug my connector. SO i have it set for 10*(plan to change it to 16*)
There is no cat, and no check engine light. Can anyone assist?
Kthx
Old Feb 4, 2008 | 05:38 PM
bump!
Old Feb 4, 2008 | 05:41 PM
rowdy235's Avatar
Compression? Is the idle speed correct?
Old Feb 4, 2008 | 06:27 PM
TORTIS's Avatar
if ya have a five speed, that is the cause. go ahead and take it out, and send it to me. i'll send ya my W56 and that will cure your problem. on the serious side, are ya losing coolant? have your ohm you temp. sensor?
Old Feb 4, 2008 | 06:47 PM
longhungsilver's Avatar
haha
Old Feb 5, 2008 | 01:37 AM
It do have the 5spd But No, coolant loss. Its not a big deal I was just curious and would like for it to idle smoothly. I think i will be checking my wires and plugs tonight.....
Old Feb 5, 2008 | 03:34 PM
4runnerx3's Avatar
Have you sprayed any carb cleaner around the intake gaskets and injector seals to rule out any leaks?
Old Feb 5, 2008 | 03:56 PM
SEAIRESCUE's Avatar
Valve adjustment or injector. Neither typically won't show up until the motor gets hot and leans out and parts expand.
Old Feb 5, 2008 | 08:02 PM
No, but tommorrow I will be replacing the intake manifold gaskets, I was going to check the fuel injectors.
Old Feb 5, 2008 | 08:21 PM
JohnnyRanger54's Avatar
do a compression check.... Mine was doing the same thing..#4 was toasted down to 40 pounds... still running okay tho', rebuilding another motor as we speak...
Old Feb 7, 2008 | 06:03 PM
TORTIS's Avatar
and, were still waiting. (pink floyd)
Old Feb 7, 2008 | 07:32 PM
I turned up the idle, replaced a few gaskets, still have it. I am thinking its the motor. Good thing taxes are coming back so I can get a new one.
Sleaker
Aug 26, 2020 06:03 AM
jetpilot
Aug 15, 2015 06:48 AM
tomczaksdiesel
Jul 26, 2015 10:35 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
kyletbert
Jul 17, 2015 11:39 AM
